Old 02-03-2009, 04:21 AM
DrunkenBrit DrunkenBrit is offline
Inheritance ambiguities
I've derived from the "FlyNavigate" class to implement my own camera class.
I'm basically trying to split the "FlyNavigate::sensitivity" function up so that I can set move and turn speeds seperately.
So far i've got:
############# MyFlyNavigation Camera ###########
import vizcam
class MyFlyNavigation(vizcam.FlyNavigate):
	MOUSE_LEFT_DOWN = False
	def __init__(self):
		# Default movement keys
		vizcam.FlyNavigate.__init__(self,'w','s','a','d')
	# Only update the mouse movement if the left mouse has been clicked
	def _camMouseMove(self,e):
		if self.MOUSE_LEFT_DOWN == True:
			vizcam.FlyNavigate._camMouseMove(self,e)
	def _camMouseDown(self,e):
		if e.button == viz.MOUSEBUTTON_LEFT:
			self.MOUSE_LEFT_DOWN = True
	def _camMouseUp(self,e):
		self.MOUSE_LEFT_DOWN = False
	# Overidden to add a bit of logic
	def _camUpdate(self,e):
		vizcam.FlyNavigate._camUpdate(self,e)
		mousePos = viz.mouse.getPosition(viz.WINDOW_PIXELS, True)
		windowSize = viz.window.getSize()
		# If the mouse cursor leaves the client window then
		# don't bother updating the _camMouseMove parent function
		if mousePos[0] <= 0:
		elif mousePos[0] >= windowSize[0]:
		elif mousePos[1] <= 0:
		elif mousePos[1] >= windowSize[1]:
	def setMoveSensitivity(self, moveScale):
		#vizcam.FlyNavigate.__moveScale = vizcam.FlyNavigate.MOVE_SPEED * moveScale
		#vizcam.FlyNavigate.sensitivity(self, moveScale, 1.0)
		self.__moveScale = self.MOVE_SPEED * moveScale
	def setLookSensitivity(self, turnScale):
		#vizcam.FlyNavigate.__turnScale = vizcam.FlyNavigate.MOVE_SPEED * turnScale
		#vizcam.FlyNavigate.sensitivity(self, 1.0, turnScale)
		self.__turnScale = self.MOVE_SPEED * turnScale
	def getMoveSensitivity(self):
		#return vizcam.FlyNavigate.__moveScale
		return self.__moveScale
	def getLookSensitivity(self):
		#return vizcam.FlyNavigate.__turnScale
		return self.__turnScale
Neither functions appear to work regardless of what "scope" I try and give to "__moveScale" or "__turnScale"...
Using "vizcam.FlyNavigate.sensitivity(self, 1.0, turnScale)" works until "vizcam.FlyNavigate.sensitivity(self, moveScale, 1.0)" is invoked, and vice versa.
I know this will be a simple mistake i'm doing for something so simple but can't seem to spot it...
DB
Old 02-06-2009, 04:03 PM
Sorry we have not had a chance to answer this yet. We'll get back to you early next week.
Old 02-09-2009, 02:17 AM
That's ok, I gathered you guys are rather busy. Thanks for informing me.
Old 02-10-2009, 12:25 PM
self.__moveScale and self.__turnScale are private to the FlyNavigate class and when you try to set those in your MyFlyNavigation class your are creating new instances of them and so the viewpoint is not affected.
When you call the sensitivity method it works
but by passing in a 1 you are re-setting the moveScale valueback to its original value
keep track of both moveScale and turnScale in your class and then pass them both to FlyNavigate.sensitivity
def __init__(self):
	self.__moveScale = 1
	self.__turnScale = 1
and then you can set each value individually and pass in the value set before
	self.__moveScale = moveScale
	vizcam.FlyNavigate.sensitivity(self, self.__moveScale, self.__turnScale)
	self.__turnScale = turnScale
Old 02-11-2009, 01:24 AM
Thanks!
