Old 10-23-2008, 03:16 PM
TrashcanPatrol TrashcanPatrol is offline
Actions while clicking an avatar
Hello, is it possible to have an action occur when you click on a specific place on an avatar? If so, how can this be done?
What I'm trying to do is have a drop-down menu where a "toolbox" is. If the player selects the correct tool, which is medicine in this case, MEDICINE will be set to True. Then, the cursor will change to an image of a pill or something, and if the player clicks on the patient's face and MEDICINE = True, the patient will respond and say "I feel better" or something to that extent.
How could I do this? I have a dropdown already that prints "Medicine equipped" when the medicine is selected, as well as turns MEDICINE to True...
Old 10-23-2008, 04:35 PM
You can use viz.pick() to find what object the mouse is pointing at. Here's some code that uses viz.pick and checks to see if the mouse is pointing at the avatar's head mesh, body mesh, or some other object. Depending on what is picked the avatar will change animations.
viz.add('court.ive')
avatar = viz.add('vcc_male.cfg', pos = [0,0,5], euler = [180,0,0])
avatar.state(1)
def onMouseDown(button):
	#if you pass in a value 1 a VizIntersect object will be returned
	object = viz.pick(1)
	if object.valid and object.name == 'casual32_m_highpoly.CMFX':
		print "you picked the avatar's head"
		avatar.state(2)
	elif object.valid and object.name == 'casual32_m_highpoly01.CMFX':
		avatar.state(4)
		print "you picked the avatar's body"
		avatar.state(1)
		print "you picked " + object.name
viz.callback(viz.MOUSEDOWN_EVENT,onMouseDown)
Old 11-18-2008, 02:23 PM
That code works great! But I am having some trouble trying to assign it to a value... sorry if I'm not very descriptive, I have it all planned out in my head and the thoughts aren't very precise when typing them out.
There's a value that is turned to 'ON' when the player selects an option from a dropdown menu... my trouble is I want the player to only be able to select an avatar and/or different parts of the avatar only when the player has selected this option, so only when the value is 'ON' the player will be able to click on the avatar. If that makes any sense >_<
What happens when I try this in my code is, instead of having the console print "You clicked the avatar's head", it says "You clicked casual32_m_highfoly.CMFX" [The code is supposed to make it say the head if you clicked the head, and whatever you clicked besides that would just be casual32_m_highfoly.CMFX or whatever the filename is for it]
How can I make it work so that you can pick a part only if a variable is enabled?
Old 11-19-2008, 12:04 PM
is this what you mean. You can only click on the avatar when the dropdown is set to ON.
avatar.state(1)
click_avatar = True
list = viz.addDropList()
list.addItems(['ON','OFF'])
list.translate(.85,.95)
def dropListChanged(e):
	global click_avatar
	if e.newSel == 0:
		click_avatar = True
		click_avatar = False
vizact.onlist( list, dropListChanged )
	if object.valid and click_avatar == True:
		if object.name == 'casual32_m_highpoly.CMFX':
			avatar.state(2)
		elif object.name == 'casual32_m_highpoly01.CMFX':
			avatar.state(4)
			avatar.state(1)
Old 12-02-2008, 02:56 PM
That is what I've been looking for! Thanks Jeff!
Best way to synchronize avatar actions mjabon Vizard 1 07-29-2008 12:15 PM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
Avatars in an array and link/unlink betancourtb82 Vizard 7 09-05-2006 05:06 PM
