Old 11-19-2008, 02:48 PM
vizLearner vizLearner is offline
vizact.ontimer problems?
Hi all,
I have a program that is supposed to give stimuli to a subject and constantly monitor a button for feedback from the subject. The button is not keyboard, but connected by adding a .dls file. The method to check the button, however, never runs. I had an older version that used a callback to a timer_event perfectly, and I don't know why it won't work now. Heres the code below that I think is relevant...
def giveStimuli():
def checkButton():
vizact.ontimer(.001,checkButton)
starttimer(0,.001,FOREVER)
viztask.schedule(giveStimuli())
Old 11-19-2008, 03:42 PM
checkButton should be getting called. try
def checkButton():
	print "in checkButton"
vizact.ontimer(0,checkButton)
this following line has incorrect syntax and you don't need it here for calling checkButton since you are using vizact.ontimer
if you were using a callback with it it would be
viz.starttimer(0,0,viz.FOREVER)
one other thing is that your timer will not run every .001 seconds. It will only get called as fast as your framerate. If you use 0 for the rate the timer will be called every frame.
2 problems with our HMD Vbents Precision Position Tracker (PPT) 1 07-26-2006 08:55 PM
avatar animation problems jrodman Vizard 1 01-18-2006 10:12 AM
Export/import problems and Vizard 3.0 release searsky Vizard 0 01-03-2006 02:34 AM
Viz PPT 1 problems Adam Precision Position Tracker (PPT) 3 08-30-2005 11:51 AM
Problems with lighting in 2.0 murm Vizard 6 04-21-2004 10:59 AM
