Old 11-11-2008, 09:17 AM
jaclyn.bill jaclyn.bill is offline
color
Quick question, I have programmers block on this.
I have a script set up in which a ball.ive pops up on the screen, moves, then repeats this in a timer loop many times.
I want the ball to occasionally be colored red. i have a previously defined list of when I want this to happen. Just picking out bits that are relevant here.
color_select = [0,50,0,0,0]
CS = color_select[i]
if CS == 50:
					ball2.color(1,0,0)
			if CS == 0:
					ball2.color(viz.clearcolor)
The ball goes red but then stays like that, but I want it to look normal on "0" trails. Is there a simple command for removing colour, the viz.clearcolor is obviously wrong.
Thank you in advance.
JB
Old 11-11-2008, 04:22 PM
I don't know what you mean by "removing the color". Every object has a color, so do you mean black (0,0,0) or white (1,1,1), or something else?
Old 11-12-2008, 02:23 AM
sorry, the ball is actually the soccerball.ive which comes with vizard. I only want to remove the red I applied to it and return it to it's original black and white with shading state. Using, 0,0,0 or 1,1,1 however, makes it look darker or lighter than the original.
thanks. JB
Old 11-12-2008, 11:16 AM
The following code shows how to apply a color and then restore the original:
#Set red color
model.color(viz.RED,op=viz.OP_OVERRIDE)
#Clear color attribute to restore original color
model.clearAttribute(viz.ATTR_COLOR,op=viz.OP_OVERRIDE)
red/green anaglyphic ghosting michaelrepucci Vizard 2 10-22-2008 11:26 AM
Another color question mjabon Vizard 4 07-31-2007 04:04 PM
changing the color of Shirt of Vizard Avatars Amit Vizard 2 09-02-2005 09:00 AM
Changing the Color of On-the-Fly Objects vjosh Vizard 1 01-05-2005 12:48 AM
Fog Color bstankie Vizard 1 06-02-2004 02:59 PM
