Old 10-28-2008, 03:25 AM
reedev reedev is offline
Documentation for coding a new render node?
Hi everyone,
I am investigating how I can add a new node to Vizard. This node will be coded in OpenSceneGraph so I am now looking at the Vizard30API. I guess I need to use example code in the directory CustomNode.
Can someone please confirm this? Where can I find documentation about the Vizard30API? For instance, is indeed standard OpenSceneGraph 1.2 used, it seems so from the header files and libs...
Thanks a lot!
Raymond
Old 10-29-2008, 11:06 AM
Vizard uses OSG 1.2. There are no docs for creating a custom node, just the sample project. We can answer any specific questions you might have.
Old 10-30-2008, 11:06 AM
Thanks for the confirmation about osg 1.2. I will proceed and ask questions when needed.
Thanks for now, regards
Raymond
