Old 10-12-2008, 10:38 PM
vjesse vjesse is offline
Max system latency for HMD?
I am trying to determine the maximum system latency for our system that implements Vizard 3.0 software. The following are the specifications:
The HMD is an nVisor SX with dual 1280 horizontal by 1024 vertical pixel resolution panels. The display presents a visual field subtending approximately 50 degrees horizontally by 38 degrees vertically. Stereoscopic images are rendered by a 1900 MHz Pentium computer with an NVIDIA GeForce 6600 graphics card and updated at an average frame rate of 60 Hz.
Head movements are tracked by a three-axis orientation sensing system (Intersense IS250 with an update rate of 150 Hz) and used to continuously update the simulated viewpoint. The position of the participant along the X, Y, and Z planes was tracked via an optical tracking system (WorldViz PPT with an update rate of 60 Hz).
Thanks for any feedback you may have!
Jesse
Old 10-13-2008, 04:00 PM
The latency can vary when using the PPT system. It should be somewhere between 60-80 milliseconds. The latency on the PPT side can vary between 20-30 ms. Assuming you are sending the data using VRPN, this will add another 5 ms. Then on the Vizard side you will have a 32-48 ms latency due to double buffering of the output images.
Old 10-13-2008, 04:09 PM
thanks!
Thank you for the feedback!
j
Old 10-13-2008, 06:47 PM
Intersense cube?
Does the Intersense cube add any additional latency?
Old 10-13-2008, 06:48 PM
The InterSense itself has latency, but it is less than the PPT latency, so it shouldn't add additional latency.
Printing of System Time Uttama_vizard Precision Position Tracker (PPT) 2 09-19-2007 03:38 PM
Patriot Polhemus System Vinicius Lima Vizard 5 07-25-2007 10:51 AM
ImmersaDesk system tracking kgarr Vizard 10 09-14-2006 12:17 PM
Particle System... again... k_iwan Vizard 2 05-09-2006 01:42 AM
accessing system speaker noise pkhoosh Vizard 2 01-25-2006 11:22 AM
