Old 09-18-2008, 01:25 PM
VDong VDong is offline
How to add individual faces onto the complete characters used in Vizard?
We have set up a series of complete characters and just need to add specialized faces onto them. The other software we have currently are PeopleMaker, 3DMeNow, MagicMorph, 3DMax.
Thanks in advance.
Dong
Stanford VRITS 2008
Old 09-19-2008, 01:56 PM
Here is a link that will show you how to get a 3DMeNow head into peoplemaker where you can create a vzf file to use in Vizard.
http://www.worldviz.com/vizhelp/p_in...eoplemaker.htm
Once you have the vzf file here is the code to replace the avatar head
#First, add the avatar and the head:
body = viz.addAvatar('vcc_male.cfg')
head = viz.addFace( 'biohead_all_morph.vzf' )
#Then, add the face to the avatar.
body.setFace( head )
#If you have trouble adding the head to your avatar
#you may need to first specify the head bone
#and then the neck bone
#Specify the head and neck bones of your avatar.
body.setFace( head, 'Bip01 Head', 'Bip01 Neck' )
if you using one of the Complete Characters you will also need to add this line to the cfg file.
head_mesh = NameOfHeadMesh.cmf
where NameOfHeadMesh.cmf is specific to the avatar you are using
Old 11-10-2008, 03:15 PM
Colin Colin is offline
related problem using faces on complete characters
We have Complete Characters and have used them in one study but would now like to try to use the same characters in a related study using different facial expressions. Is there a way to do this?
Also, where are people finding 3dMeNow? It seems to be off the market.
Old 11-12-2008, 11:05 AM
3DMeNow is used for creating custom heads using pictures of a person. If you just want to create morphs for the existing face of a Complete Character you do not need 3DMeNow or Peoplemaker. All you need is 3ds Max and the Max files that come with the Complete Characters.
Vizard and Augmented Reality realvision Vizard 4 04-04-2008 11:59 AM
Complete Characters and 3dmax dan12345 Vizard 3 02-07-2008 07:32 PM
Vizard won't run wouters Vizard 5 02-05-2008 12:12 PM
Fall 2007 release of Vizard R3 3 D Announcements 0 10-15-2007 05:50 PM
McAfee Privacy Service 8.1 causes Vizard not to run mspusch Vizard 0 03-01-2007 09:24 PM
