Old 08-28-2008, 12:27 PM
Enlil Enlil is offline
Polhemus woes
I am having an issue with the Polhemus, and am not sure whether it is a Vizard or Polhemus issue (or whether you have heard of the problem). The problem is that the coordinate system of the patriot sensor sometimes is reversed on startup. This would not be an issue (I could just scale it), but it seems arbitrary in which system it chooses.
I tried to follow the notes in the Polhemus help (ie. below the sensor, 12-14 inches behind the sensor with the front of the marker aligned with the tail), but that didn't seem to help.
So, any suggestions other than putting in a toggle to reverse the scale?
Christian
Old 08-29-2008, 01:02 AM
tobin tobin is offline
The device can be reliable but you have to do a few things:
  1. In PiMGR, set the hemisphere tracking on.
  2. After power cycling the unit, the hemisphere gets locked the first time Vizard connects to the Polhemus device. When connecting for the first time since powe cycling, hold your sensor/s all in the +X Polhemus hemisphere (side opposite the cord).
  3. From that point on (at least until you power cycle again), you should have no more switching.
Old 09-02-2008, 10:09 AM
I'll try it, thanks!
Christian
Patriot Polhemus System Vinicius Lima Vizard 5 07-25-2007 10:51 AM
Vizard and Polhemus Patriot bjgold Vizard 8 09-18-2006 03:05 PM
Polhemus Patriot Tracking System: Support/Problem FrankPSchulte Vizard 3 08-10-2006 05:50 PM
Support Polhemus Insidetrack and Cybermind Visette Pro HMD mspusch Vizard 1 03-08-2003 12:14 PM
