Control of timers
I am using viz.play and viz.pause to control timers. However, I am looking at stopping and starting individual timers. Can I use Timer IDs to control timers?
VizMaster
If you want to control individual timers, then I recommend using the vizact library, specifically, the vizact.ontimer function. Here is some sample code that creates a simple timer and uses the keyboard to toggle it on/off:
def DoSomething():
print viz.getFrameNumber()
#Create timer that calls 'DoSomething' every 1 second
mytimer = vizact.ontimer(1,DoSomething)
def ToggleTimer():
mytimer.setEnabled(viz.TOGGLE)
#Toggle timer on/off when spacebar pressed
vizact.onkeydown(' ',ToggleTimer)
Scenario is:
Several test subjects have X amount of time to do something. During that time I need to pause one upto all test subjects. Then resume with whatever time they have left. Do class timers work independent of each other. Can I play and pause within a class?
VizMaster
Does <node3d>.pauseActions pause between actions in a pool or does it pause the actions. Will it pause a timer in the pool?
VizMaster
You cannot play/pause timers within a class timer. <node>.pauseActions will pause the running action. If you have a vizact.waittime action, it will be paused and resumed from where it was paused.
Can you answer:
VizMaster
No, you cannot. I believe I answered that in my previous post. Sorry if it was not clear.
| Viewpoint control | Vinicius Lima | Vizard | 6 | 08-20-2007 06:51 PM |
| intersense: Failed to set control word on \\.\COM1 | OueOue | Precision Position Tracker (PPT) | 2 | 01-18-2007 01:51 PM |
| timers and director function | Jerry | Vizard | 1 | 06-22-2006 10:47 AM |
| multiple timers | paulpars | Vizard | 4 | 06-02-2006 11:12 AM |
| Overriding Mouse Control | Vygreif | Vizard | 3 | 09-28-2005 09:51 PM |
