Old 08-20-2008, 02:23 PM
vizmaster vizmaster is offline
Control of timers
I am using viz.play and viz.pause to control timers. However, I am looking at stopping and starting individual timers. Can I use Timer IDs to control timers?
VizMaster
Old 08-21-2008, 11:57 AM
If you want to control individual timers, then I recommend using the vizact library, specifically, the vizact.ontimer function. Here is some sample code that creates a simple timer and uses the keyboard to toggle it on/off:
def DoSomething():
	print viz.getFrameNumber()
#Create timer that calls 'DoSomething' every 1 second
mytimer = vizact.ontimer(1,DoSomething)
def ToggleTimer():
	mytimer.setEnabled(viz.TOGGLE)
#Toggle timer on/off when spacebar pressed
vizact.onkeydown(' ',ToggleTimer)
Old 08-21-2008, 03:23 PM
Scenario is:
Several test subjects have X amount of time to do something. During that time I need to pause one upto all test subjects. Then resume with whatever time they have left.
Do class timers work independent of each other. Can I play and pause within a class?
VizMaster
Old 08-21-2008, 03:30 PM
Does <node3d>.pauseActions pause between actions in a pool or does it pause the actions. Will it pause a timer in the pool?
VizMaster
Old 08-21-2008, 04:42 PM
You cannot play/pause timers within a class timer. <node>.pauseActions will pause the running action. If you have a vizact.waittime action, it will be paused and resumed from where it was paused.
Old 08-22-2008, 09:45 AM
Can you answer:
VizMaster
Old 08-22-2008, 10:36 AM
No, you cannot. I believe I answered that in my previous post. Sorry if it was not clear.
Viewpoint control Vinicius Lima Vizard 6 08-20-2007 06:51 PM
intersense: Failed to set control word on \\.\COM1 OueOue Precision Position Tracker (PPT) 2 01-18-2007 01:51 PM
timers and director function Jerry Vizard 1 06-22-2006 10:47 AM
multiple timers paulpars Vizard 4 06-02-2006 11:12 AM
Overriding Mouse Control Vygreif Vizard 3 09-28-2005 09:51 PM
