questions on how to create a form
can someone teach me how to create a form used to gather infomation entered by a user?
I need to do it in this way. If I pressed a key such as 'p', the animation would be paused. Then the form comes up. After the form is filled in, I press a 'submit' button to pass them to somewhere. I already tried to use vizinfo and vizmenu. but they can just show a list , not a real form like what we did in the Microsoft Office. Thanks a lot ![]()
You can try using the undocumented vizdlg module for displaying forms. It allows more advanced form layouts and dialog like components. Here is sample code that creates a custom dialog/form and displays it when the 'p' key is pressed:
import vizdlg
class MyForm(vizdlg.Dialog):
def __init__(self,**kw):
#Initialize base class
vizdlg.Dialog.__init__(self,**kw)
#Add row of checkboxes
row = vizdlg.Panel(layout=vizdlg.LAYOUT_HORZ_BOTTOM,border=False,background=False,margin=0)
row.addItem(viz.addText('Checkboxes'))
self.check1 = row.addItem(viz.addCheckbox())
self.check2 = row.addItem(viz.addCheckbox())
self.check3 = row.addItem(viz.addCheckbox())
#Add row to dialog content section
self.content.addItem(row)
#Add a subgroup containing slider/textbox
group = vizdlg.Panel()
#Add row for slider to subgroup
row.addItem(viz.addText('Slider'))
self.slider = row.addItem(viz.addSlider())
group.addItem(row)
#Add row for textbox to subgroup
row.addItem(viz.addText('Textbox'))
self.textbox = row.addItem(viz.addTextbox())
group.addItem(row)
#Add group to dialog content section
self.content.addItem(group)
#Hide cancel button
self.cancel.visible(0)
#Rename accept button to 'submit'
self.accept.message('Submit')
import viztask
def FormTask():
#Create input form
form = MyForm(title='Form title')
#Link form to center of screen
viz.link(viz.MainWindow.CenterCenter,form)
while True:
#Wait for 'p' key to be pressed
yield viztask.waitKeyDown('p')
#TODO: Pause simulation
#Display form
yield form.show()
if form.accepted:
#User pressed 'Submit', process data
print 'Checkboxes:',form.check1.get(),form.check2.get(),form.check3.get()
print 'Slider:',form.slider.get()
print 'Textbox:',form.textbox.get()
#TODO: Resume simulation
#Remove form when completely finished with it
form.remove()
viztask.schedule( FormTask() )
Wow.....many thanks. I really appreciate it. This is exactly what I considered. If the vizard could create many complex models, there should be some ways to make tables. However, could you plz tell me how I can get the specific use of this module? I just tried your sample code and part of my purpose already was achieved. As you mentioned , something more advanced is allowed. How can I do it? Since this module is not documented , it's really hard to know its exact usage which is vital to me.
Regards Last edited by xingxing; 02-20-2008 at 07:29 PM. |
You will need to be more specific about what you are trying to accomplish. Do you have a screenshot of a form you would like to mimic?
I finally got a place to upload the form in jpg format. This is basically what I wanna do. In addition , as the example provided previously, I also need the animation paused when I presss the "P" key. Is there an easy way to do this? I really need this "pause" action. Thanks for help. ![]()
What kind of animation are you talking about? (vizact animation, avatar animation, etc..)
Hi, my work is about avatar animation.
You can use the following command to pause an avatar:
avatar.speed(0) Code:
avatar.speed(1) |
How would I rewrite this so that the vizdlg is not in a yield statement. I try calling form.show() directly and nothing is displayed. I want to gather some user information then loop on a set of inputs. I would like to use vizdlg for the control I have over the form.
VizMaster
The show method just sets the dialog visible, waits for either the accept or cancel button to be pressed, then hides the dialog. If you do not want to use a task, then you can manually perform these steps. Here is the code for the show command:
def show(self): """Create task that displays dialog""" #Show dialog self.visible(1) #Yield until accept or cancel button is released d = viz.Data() yield viztask.waitButtonUp([self.accept,self.cancel],d) #Save whether the dialog was accepted self.accepted = d.button is self.accept #Hide dialog self.visible(0) |
When I add the yield statement I lose visibility of the form. I don't manually change the visibility. What gives?
VizMaster
You should not be using yield statements if you are not using tasks. Here is a sample script that displays a dialog without using tasks. Use the spacebar to toggle the visibility of the dialog.
import vizdlg
#Create empty dialog
dlg = vizdlg.Dialog(title='Dialog title')
#Link dialog to center of window
viz.link(viz.CenterCenter,dlg)
#Toggle dialog visibility when spacebar is pressed
vizact.onkeydown(' ',dlg.visible,viz.TOGGLE)
viz.add('gallery.ive')
Thanks, This is what I ended up with, but I don't want to display the gallery until I hit accept. I want to wait for the dialog to be done. Say the dialog asks for the user to make a button choice then accept before the gallery is displayed.
import viz import vizdlg viz.go() #Create empty dialog dlg = vizdlg.Dialog(title='Dialog title') #Link dialog to center of window viz.link(viz.CenterCenter,dlg) #Toggle dialog visibility when spacebar is pressed vizact.onkeydown(' ',dlg.visible,viz.TOGGLE) # Look for the Accept button to be pressed. vizact.onbuttondown(dlg.accept,dlg.visible,viz.TOG GLE) viz.add('gallery.ive')
VizMaster
Is there a specific reason you don't want to use tasks? They are made for these type of cases where you want a linear flow of operations. Either way, here is how you would handle this without tasks. The code sets up a callback for the accept button and calls a function when it is clicked.
import vizdlg
dlg.visible(1)
#Hide dialog and add gallery when accept is pressed
def DialogAccept():
dlg.visible(0)
vizact.onbuttonup(dlg.accept,DialogAccept)
#15
I am new to this type of programming. If you add a
print 'The End' at the end of the script the print statement is executed. This tells me execution continues. So I must not be approaching this the right way. What I am trying to do is prompt a user for his name. He enters it using a onscreen keyboard I have coded. Once the user has entered their name they loop over a sequence of dialogs for a set amount of time. In my code the other dialogs appear since the execution continues.
VizMaster
#16
If your print statement is in the global scope then it will be executed during the script loading. All that sample code does is register a callback for when the accept button of the dialog is clicked and calls the specified function. If you need to display a series of dialogs sequentially, then I highly recommend using tasks. Using a callback approach will become very difficult once you have more than one dialog.
| Create my own animations | michelcm3 | Vizard | 1 | 09-21-2007 09:53 AM |
| how to create morph from the comple characters CD | michelcm3 | Vizard | 9 | 07-19-2007 10:15 AM |
| Alpha and Texturing questions | Manny | Vizard | 3 | 03-08-2007 11:55 AM |
| General Questions about Vizard: World Viz | dav | Vizard | 5 | 08-28-2006 03:44 PM |
| Antialiasing questions | oodini | Vizard | 1 | 12-06-2005 12:08 PM |
