Old 04-29-2008, 03:42 PM
whj whj is offline
texture problem with .wrl file
I created a simple scene by maya 7.0 and exported it as file "test.wrl". The scene includes both polygon and nurbs surfaces with texture. When I loaded it into vizard using viz.add('test.wrl'), the texture was gone. Could anybody help me find the reason and fix it? (Files are attached.)
ID:	234   Click image for larger version
Old 04-30-2008, 11:09 PM
I believe the problem is that your vrml file uses a Switch node, which our loader does not currently support. I will try to add support for this and post an update if successful. I'm not familiar with Maya, so I don't know of a workaround, sorry
Old 05-01-2008, 10:23 AM
whj whj is offline
Thanks for the reply.
What's Switch node? Is it a concept in Vizard or Maya?
I found that if I export the model to obj file, at least the polygon surface works fine, but all nurbs surfaces lost texture. So I'm going to convert all nurbs surfaces into polygon. Does that mean obj file works better than wrl file in Vizard?
Old 05-01-2008, 10:42 AM
I've updated our loader to support the Switch node and your test model works fine now. Email me at lashkari@worldviz.com and I will send you the updated loader.
Old 05-01-2008, 10:56 AM
whj whj is offline
I also found that if I use "repeat UV" in texture mapping polygon model, all texture lost again. But after I convert the obj file into 3ds file, it works fine. Does it mean 3ds file is more reliable than obj file in Vizard?
Old 05-01-2008, 03:09 PM
whj whj is offline
The the updated loader for the Switch node works very well. Thanks a lot.
Skydome texture problem theuberk Vizard 2 01-18-2008 06:56 AM
Problem on adding OSG file felixchc Vizard 4 10-06-2006 12:26 PM
texture mapping problem dellatails Vizard 1 03-12-2006 12:13 PM
avatar head texture issues rconrey Vizard 3 11-17-2004 05:05 PM
Texture map rendering problem JRichizzle Vizard 4 03-04-2004 08:20 AM
