Old 03-11-2008, 01:03 PM
RedSpikeyThing RedSpikeyThing is offline
custom DLE files
I'm trying to create a sensor that requires a custom constructor. The parameters required are NOT compatible with sensor.sendCommand, so I think a DLE is the way to go. I can't seem to find any documentation on creating DLEs, so would anyone be able to point me in the right direction?
Thanks!!
Old 03-11-2008, 05:57 PM
The SDK for dle plugins has not been released yet. Either way, extension objects receive the same type of command data as normal sensors, so I'm not sure how much it will help you. What kind of data are you trying to pass to your plugin?
Old 03-11-2008, 06:15 PM
hmmm I was under the impression that DLE's could have different constructors than DLS's. I'm trying to make a sensor that generates its data by merging two other sensors. Ideally it would just be a matter of passing the two sensors as parameters to the constructor. My other idea was more of a hack....cast the memory address of the sensor into a float and pass it as a command argument, where the C++ part casts it back into a memory address. I don't know if this will work, but it seems feasible.
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 12:21 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 03:23 PM
Including Files that Include Other Files vjosh Vizard 1 09-21-2004 04:44 PM
animating custom faces: in search of "open_mouth" morphs vr_boyko Vizard 1 09-16-2004 10:30 AM
Creating Custom Avatar Heads farshizzo Vizard 22 09-12-2004 09:23 PM
