Old 02-01-2008, 09:32 AM
rubberpimple rubberpimple is offline
Left Hand
I need to animate a LEFT hand in Vizard...is there some easy way to mirror the stock hand.cfg??
David
Old 02-01-2008, 10:05 AM
If you are using the hand module, then you can use the following code:
import hand
h = hand.add(sensor)
#Display as left hand
h.leftHand()
If you are manually loading the hand.cfg file, then you can us the following code:
hand = viz.add('hand.cfg')
hand.scale(-1,1,1)
hand.enable(viz.FLIP_POLYGON_ORDER)
Old 02-05-2008, 02:00 PM
Using the second option gives me a darkly-shaded, flipped-over (palm facing up) hand. Is there a better way?
David
Old 02-05-2008, 02:07 PM
If you run the following script does the shading on the left hand look darker than the right hand?
rhand = viz.add('hand.cfg',pos=(0.1,1.8,0.5),euler=(0,-90,0))
lhand = viz.add('hand.cfg',pos=(-0.1,1.8,0.5),euler=(0,-90,0))
lhand.scale(-1,1,1)
lhand.enable(viz.FLIP_POLYGON_ORDER)
rhand.add(vizact.spin(0,0,1,45))
lhand.add(vizact.spin(0,0,-1,45))
Old 02-05-2008, 03:03 PM
Wow...those look perfect. I think there is something else in my code that is mucking things up. I'll investigate...
David
Old 02-05-2008, 03:05 PM
Does messing with window POV commands have this effect?
David
Old 02-05-2008, 03:07 PM
Can you just post a sample script of yours that makes the left hand darker?
Old 02-05-2008, 03:16 PM
Here it is:
myHand = viz.add('hand.cfg',pos=(0.1,1.8,0.5),euler=(0,-90,0))
myHand.scale(-1,1,1)
myHand.enable(viz.FLIP_POLYGON_ORDER)
myHand.setScale(20,20,20)
It's the setScale command. Not sure why, but the hand becomes right handed and appears darker.
David
Old 02-05-2008, 03:17 PM
Your sample code is undoing the negative x scale, which is required for inverting the hand and making it look left handed. Use the following code instead:
myHand.setScale(-20,20,20)
Old 02-05-2008, 03:20 PM
Nice! Many thanks...
David
cameras get confused by many LEDs tavaksai Precision Position Tracker (PPT) 9 05-19-2007 04:52 PM
Hand Steve_HT Vizard 1 03-19-2007 12:51 PM
5DT left and right glove glepoura Vizard 3 02-06-2007 04:41 AM
Use of 5DT Ultra left handed glove pattie Vizard 1 08-26-2006 12:59 PM
hand model features? halley Vizard 1 03-13-2006 10:11 AM
