Old 01-20-2008, 02:19 PM
johannes2 johannes2 is offline
onactionend
moving to Vizard 3 from Vizard 2.5 onactionend seems to work differntly:
Old working code:
def onactionend(object,action):
if object == screenWall and action == viz.MOVE:
putGraphOnScreenWall()
viz.callback(viz.ACTION_END_EVENT,onactionend)
New code, not working yet:
def onactionend(e):
print 'end',e.object,e.action
if e.object is screenWall and e.action is viz.MOVE:
What to do?
Best,
Johannes
Old 01-23-2008, 12:18 PM
Can you post a simple working example that reproduces the problem? Also, please use the [code][/code] tags when posting code samples. It will preserve the tabs which is necessary for python code.
Old 02-12-2008, 02:35 AM
Thank you for being fast and sorry for beeing slow - too many other things right now
TypeError: onactionend() takes exactly 2 arguments (1 given)
** WARNING: <node>.goto will be deprecated in future versions of Vizard, use vizact.goto instead
Sample Code:
graphOnWallFinished=0
def putGraphOnScreenWall():
	global graphBasket, graph1, graph2, graph3, graph4, graph5, graph6,graphOnWallFinished
	print 'adfasdf',screenWall.get(viz.POSITION)[1]
	if checkboxWall.get()==1 and screenWall.get(viz.POSITION)[1]==0:
			#moveDown=vizact.move(0,0,0,1)
			#screenWall.add(moveDown)
			graph4.graphWhat=graph1.graphWhat
			graph5.graphWhat=graph2.graphWhat
			graph6.graphWhat=graph3.graphWhat
			resetObjects()
			#make existing graphs invisible
			for graphInstance in graphBasket:
					graphInstance.coordinateShow=0
					graphInstance.showCoordinateSystem()
			#print '123213',graphBasket
			graphBasket=[]
			#print graphBasket
			graphBasket.append(graph4)
			graphBasket.append(graph5)
			graphBasket.append(graph6)
				graphInstance.setLabelTextGraph(graphInstance.graphWhat)
				graphInstance.adjustCoordSys(3,1)
				graphInstance.adjustCoordSys(3,0)
				graphInstance.coordinateShow=1
			graphOnWallFinished=1
Old 02-12-2008, 10:52 AM
Can you post a working script? I can't actually run the code you posted since it is not a fully working script. Either way, you might want to look at the documentation for viz.ACTION_END_EVENT. It shows a simple example on how to correctly handle the callback.
Do you know how to send a value for 'pool' to the onActionEnd function? ghazanfar Vizard 1 03-22-2007 10:25 AM
