Old 12-07-2007, 08:06 AM
JMOwens JMOwens is offline
Timer cycling correctly?
Hi all,
I have a timer running my program at 1/60 second, as indicated below:
def masterLoop(num):
[main program here]
viz.callback(viz.TIMER_EVENT,masterLoop)
viz.starttimer(0,1/60,viz.FOREVER)
However, when I insert a viz.elapsed() into the callback, it returns values of roughly 0.004. I may be misunderstanding the function, but shouldn't it be returning 0.017, which is 1/60? Sorry if this is a dumb question, but it's really important that this timer is cycling correctly. Thanks for your help!
Old 12-07-2007, 10:35 AM
In Python, the result of dividing two integers will be another integer. Try the following in the interactive interpreter:
>>> 1/60
0
>>> 1/60.0
0.016666666666666666
>>> 1.0/60
So your code is setting a timer to expire every 0 seconds, which will be every frame. You will need to do the following instead:
viz.starttimer(0,1/60.0,viz.FOREVER)
Old 12-07-2007, 10:57 AM
Oh man, thanks a lot - I knew that, but forgot it in the context of a fraction! Doh. Thanks again.
timer question again Elittdogg Vizard 3 10-18-2007 11:29 AM
Timer speed Jerry Vizard 1 12-08-2006 12:01 PM
timer paulpars Vizard 2 06-14-2006 03:31 PM
Timer event documentation pkhoosh Vizard 1 10-21-2005 11:12 AM
multiple timer trouble exhale Vizard 2 04-26-2005 01:21 AM
