Old 07-11-2006, 03:44 PM
spacefarer spacefarer is offline
eMagin
I tried to use eMagin's Z800 HMD with a 6 DOF head tracker and had an error which says "** ERROR: Failed to create Emagin IC3DVisor object". I'm using 3DVisor Utility Rev C (635) and my script is as follows. I'd apreciate your help. Thanks!
visor = viz.add('emagin.dls')
def mytimer (num):
data = visor.get()
print data
viz.starttimer(0, 0.1, viz.FOREVER)
Old 07-12-2006, 09:32 AM
The eMagin is a somewhat temperamental device as it only allows one program to connect to it at a time. The Vizard driver works most consistently when the eMagin Utility program is not installed on the computer. Uninstall that and give it a try.
Paul Elliott
WorldViz LLC
Old 09-13-2006, 05:46 AM
Plymouth Plymouth is offline
Can't connect error
I followed the install instructions for the driver you posted (including uninstalling the z800 utility program), but when I call emagin.dls I get error:80000016, can't connecto to device. Do you have any idea what I might be able to do to fix this?
Old 09-13-2006, 08:32 AM
Not sure but here are some possible problems:
--One can't move the headset when connecting
--No other programs can be connected to headset
--Need to turn headset on with button
Paul Elliott
WorldViz LLC
Old 05-31-2007, 10:37 AM
It seems that sometimes Vizard cannot connect to the eMagin after its USB cable has been unpluged and pluged back in. To fix this re-run the setup2k.exe in the install stuff folder of the zip when the eMagin is pluged in.
Paul Elliott
WorldViz LLC
Old 07-26-2007, 11:00 AM
New eMagin sensor driver release. This .dls file keeps the display from turning off after 5 minutes.
Paul Elliott
WorldViz LLC
Old 09-28-2007, 11:36 AM
I have attached the latest Vizard eMagin driver and modified the installation instructions.
Installing Emagin for Vizard:
1. Install the Emagin SDK by downloading the SetupWizard from here:
http://www.3dvisor.com/support.php
2. Run the Setup Wizard and install the software.
3. Plug in the eMagin USB cable.
4. Install the eMagin USB drivers by pointing the Windows hardware installer to
C:\Program Files\eMagin\drivers
5. You can now access the orientation data of the eMagin in Vizard:
viz.add('gallery.ive')
sensor = viz.add('emagin.dls')
viz.link(sensor, viz.MainView)
Paul Elliott
WorldViz LLC
Old 10-31-2007, 10:06 AM
By the by, the latest eMagin.dls driver is included in the latest Vizard release. So all you need to do is install the SetupWizard.
Paul Elliott
WorldViz LLC
Old 10-31-2007, 10:11 AM
You can also directly control the eMagin's display via the "Lab Tool" utility available on the eMagin support download page.
Paul Elliott
WorldViz LLC
Old 04-10-2008, 10:10 AM
The latest eMagin driver is included in the Vizard installer. No need to use the one attached to this thread.
Paul Elliott
WorldViz LLC
