Old 10-23-2007, 02:17 AM
jaclyn.bill jaclyn.bill is offline
text output
Dear all,
I'm using the script below in order to move a ball around the screen and save data to two text files. The first records keyboard and time responses, the second records x,y,z of the ball across time.
Whilst the keyboard responses are recording to text fine and the x,y,z data is visible in the output screen of vizard, only the last x,y,z co-ord is saving to the text file. Is there a simple command I'm missing, or is the issue because I'm trying to write two files at once?
I would be grateful for some help on this.
Thank you.
Jac
####code for recording the data.
def RecordTimer(pos, currentTime):
	file = open ('time.txt','w')
	currentTime = viz.tick()
	pos = gball.getPosition()
	save = '%d %.4f %.4f %.4f'%(currentTime * 1000,pos[0],pos[1],pos[2])###original
	file.write(save)
	file.flush()
	print save
def RunSimulation():
	#Repeat simulation indefinitely
	while True:
		#Wait for left mouse button to be pressed
		yield viztask.waitMouseDown(viz.MOUSEBUTTON_LEFT)
		#Place ball in starting position
		gball.add(motionseq)
		#Start timer to record ball position
		recordTimer = vizact.onupdate(0,RecordTimer)
		#Wait for ball to finish move action
		yield viztask.runAction(gball.add(motionseq))
		#Stop timer
		vizact.removeEvent(recordTimer)
viztask.schedule(RunSimulation())
import vizinfo
# Opens file 'response.txt' in write mode
file = open('response.txt', 'w')
# Define a function that saves data
def SaveData(currenttime, key):
    out = str(currenttime) + '\t' + key + '\n'
    file.write(out)
    file.flush()
    print out
# Define a function that is called every time a keyboard button is pressed
def mykeyboard(key):
    # Calls the function SaveData and hands it the current time and key
    SaveData(viz.tick(),key)
# Defines a callback for keyboard events
viz.callback(viz.KEYBOARD_EVENT, mykeyboard)
Old 10-23-2007, 10:46 AM
You are opening the file during every iteration of your timer, this is very inefficient. Also, whenever you open a file in write mode (i.e. 'w') it will overwrite the current contents of the file. What you should do is open the file once, and just write to it inside your timer. Example:
logFile = open ('time.txt','w')
	logFile.write(save)
	print save
Also, if you want to append data to a file, you can open it using the 'a' flag, instead of the 'w' flag.
Old 10-24-2007, 06:37 AM
That's great, thanks for your help.
Jac
