Old 10-22-2007, 08:16 PM
AlyssaK AlyssaK is offline
Status bar in user interface
Hi everyone,
I'm looking at creating a status bar to display information. I'm using the following code as a starting point, however there is a syntax error! Its as really basic problem I know.
statusBar = viz.addTextbox()
statusBar.translate(0.928,0.98)
File "main.py", line 5, in ?
from gui import GUI
File "gui.py", line 68
SyntaxError: invalid syntax
If you have alternate code please post a reply or have found where im going wrong.
Thanks!!!
Old 10-22-2007, 11:21 PM
I have updated the code and the same syntax error exists
statusbox = viz.addTextbox()
statusbox.length(2)
statusbox.setPosition(.5,.8)
statusbox.overflow(viz.OVERFLOW_GROW)
Old 10-23-2007, 11:14 AM
Can you post the code for your entire script using the [code][/code] tags? The error you are getting is either caused by the previous line or bad indentation.
Old 10-26-2007, 01:05 AM
Thanks for the reply.
It was bad indentation. Solved by Cntrl A and Alt 'T' (Tabify region).
