Old 07-30-2007, 11:57 AM
bjgold bjgold is offline
5dt driver question
All:
When using our 5DT Data Glove 5 Ultra glove, we import it via
gloveSensor = viz.add('5dt.dls')
If we were to be using both a Data Glove 5 and a Data Glove 14 Ultra, would this same code above be able to distinguish between the two gloves? Or would we need to use a different driver? Of course, due to the different number of sensors on the two gloves, the values sent to/returned from the glove would differ, but I didn't know if the single 5dt.dls driver could drive both gloves.
Thanks!
Old 07-30-2007, 12:09 PM
You should be able to connect to 2 gloves by specifying the port for each glove. Example:
PORT_5DT_USB = 0
glove1 = viz.add('5dt.dls')
PORT_5DT_USB = 1
glove2 = viz.add('5dt.dls')
Old 07-30-2007, 12:13 PM
And that would automatically know that glove1 is the 5 sensor and glove2 the 14 sensor one without any work on our end?
Old 07-30-2007, 12:17 PM
You would need to detect that yourself. You can check the length of the data list returned by the gloves to figure out which one is 14 sensor and 5 sensor. The 14 sensor glove will return a longer list.
Old 07-30-2007, 12:20 PM
Ahh, great. Thanks!
