Old 07-02-2007, 02:02 PM
djdesmangles djdesmangles is offline
Question Impostors ?
Hello Wizards !!
I tried to export a 3dsmax scene by including the Impostors OSG Helper, but no objects render in the scene under vizard… What happened ?
viz.FOREVER,
D.
Old 07-02-2007, 03:51 PM
I'm not sure what is wrong. We have gotten impostors to work successfully by following the instructions found here. When you say that no objects are rendered, are you referring to the impostor object or all objects?
Old 07-03-2007, 08:41 AM
Unhappy My scene is empty
Hi Farshi...
My scene is empty. My objects are rendered only when I remove them from the Impostor Helper...
viz.FOREVER
D.
Old 07-03-2007, 03:24 PM
Which version of OSGExp are you using? Can you try exporting a sample file to the .osg format and post it here? You don't need to post the textures, I just want to examine the .osg file to make sure it is correct.
Old 07-03-2007, 04:18 PM
OSG file...
Yo !!
I'm using OSG Exporter 0.9.3. I've posted the osg file to...
See ya later...
viz.FOREVER,
D.
File Type: zip impostors.zip (381 Bytes, 1808 views)
Old 07-05-2007, 10:43 AM
It looks like the impostor is not being exported at all. When exporting the model, did you check "Helpers" under the "Export to Scene" section of the export dialog?
Old 07-05-2007, 10:58 AM
Export Dialog screenshot
Hello Farshi:
I send you a screenshot of the export diag.
See ya !!
viz.FOREVER
D.
Old 07-06-2007, 07:34 AM
Question Screenshot
Hello Farshi,
I've sent you a screenshot of my export diag... Did you find something ?
viz.FOREVER,
D.
Old 07-06-2007, 10:10 AM
Everything looks good. I'm not sure what is going on. I'm going to have our modeler test this out to see if it works here.
Old 07-10-2007, 05:31 PM
Sorry for the delay. The problem was that the OsgExp installer did not includ a certain dll needed for exporting impostors. I've updated the installer on our downloads page. Can you try it out and let me know if you have any more problems?
Old 07-12-2007, 06:46 PM
Thumbs up It's working...
Hello Wizards,
Impostor Helper is now working fine !!
Thank!!
viz.FOREVER,
D.
