Old 05-23-2007, 11:23 AM
TunTun TunTun is offline
question about yaw, pitch, roll
Hello
I have a question about the command <viewpoint>.rotate(x,y,z,angle). It's said x specifies yaw, y specifies pitch, and z specifies roll. Also viz.get(viz.HEAD_EULER) returns the same order.
my code is:
view.rotate(1,0,0, 90)
pe = viz.get(viz.HEAD_EULER)
print 'orientation of viewpoint is at: ', pe[0], ', ', pe[1], ', ', pe[2]
It's supposed to change orientation in yaw (vertical axis), and get result (90.0, 0.0, 0.0). But my result is (0.0, 90.0, 0.0).
Then I tried other two directions:
If: view.rotate(0,1,0, 90)
then result is: (90.0, 0.0, 0.0)
If: view.rotate(0,0,1 90)
then result is: (0.0, 0.0, 90.0)
It seems the yaw and pitch values somehow switch each other. Only roll value is what I expected. Can anybody tell me what happened?
Thanks a lot.
Old 05-23-2007, 11:30 AM
Those values are correct. The command view.rotate(1,0,0, 90) will rotate the view 90 degrees along the x-axis, which represents the pitch in euler angles.
Old 05-23-2007, 01:46 PM
Jerry Jerry is offline
That's always bothered me too. Yaw is rotation about the y axis.
If you do it this way:
view.rotate(1,0,0,90)
the Eulers come back 0,90,0
but if you do it this way:
view.rotate(90,0,0)
the Eulers are 90,0,0
