Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Old 05-05-2007, 07:03 PM
pattie pattie is offline
Client Server Networking Problem
Hi guys:
I have been playing around with the client server example.
I have been experiencing a problem for a few days now:
I am using the server script and two clients to connect to the server.
Every time a client connects to the server, the server correctly receives the UPDATE event but the connected clients never receive it, therefore the client's update() function is never called and the client never sees the other connected clients. I do not understand why:
- the client to server communication works fine;
- the server to client communication does not work;
- the client to client communication does not work (viznet.client.sendAll).
I have disabled any possible firewall or antivirus installed on the machines.
Am I doing something wrong?
Patrick
Old 05-07-2007, 10:30 AM
Try pinging the server computer from the clients using the server's logical name. Vizard uses the computer's logical name to determan their IP address.
Old 05-07-2007, 11:48 AM
Client server Networking
Both clients can ping the server using either the IP address or the name
Old 05-09-2007, 12:05 PM
Client Server networking problem
Hi guys:
I think you might want to take a look at the sendAll function. It looks like it does not send the events to the clients (server works fine).
Is it a bug in the client server code or did I forget something?
Patrick
Old 05-09-2007, 12:52 PM
Are you using Vizard 2.5? Because the viznet module will only work with Vizard 3.0
Old 05-10-2007, 01:41 PM
Cleint Server Networking problem
I am using the very last version on all machines
Old 05-10-2007, 01:48 PM
I tested the sendAll command and it worked fine here. Can you post the scripts you are using? Also, in the future, please post Vizard 3.0 related question in the Vizard 3.0 forum.
Old 05-11-2007, 03:25 PM
Client Server Networking problem
Sorry about posting this thread in the wrong place.
Here is the code I am using:
SERVER SERVER SERVER SERVER:
import viznet
viz.clearcolor(.2,.2,.4)
view.setPosition(70,45,-60)
view.lookat(0,0,10)
objectList = ['duck.wrl', 'logo.wrl', 'male.cfg', 'female.cfg' ]
maze = viz.add('tankmaze.wrl')
objects = {}
UPDATE = viznet.id('update')
CLIENT_DISCONNECTED = viznet.id('client_disconnected')
CHAT = viznet.id('chat')
viznet.server.start(port_in=14950, port_out = 14951)
def onStartClient(e):
print '** Client joined:', e.sender
viz.callback(viznet.CLIENT_CONNECT_EVENT, onStartClient)
def onStopClient(e):
print '** Client left:', e.sender
viznet.server.send(CLIENT_DISCONNECTED, client=e.sender)
objects[e.sender].remove() #Remove object from map
del objects[e.sender] #Delete user from array
viz.callback(viznet.CLIENT_DISCONNECT_EVENT, onStopClient)
def update(e):
try:
objects[e.sender].setPosition(e.pos)
objects[e.sender].rotate(e.ori)
except KeyError:
objects[e.sender] = viz.add(objectList[e.object],scale=
2,2,2],pos=e.pos,euler=e.ori)
objects[e.sender].tooltip = e.sender
viz.callback(UPDATE, update)
import viztip
tth = viztip.ToolTip()
tth.start()
tth.setDelay(0)
def updateChat(msg):
text.message('\n'.join(text.getMessage().split('\n ')[1:])+'\n'+msg)
text = viz.addText('\n\n\n\n', viz.SCREEN) # send 4 carriage returns to screen
text.alignment(viz.TEXT_LEFT_BOTTOM)
text.fontSize(25)
text.translate(0.05,0.08)
input = viz.addText('>_', viz.SCREEN) # Add Chat prompt
input.alignment(viz.TEXT_LEFT_BOTTOM)
input.fontSize(25)
input.translate(0.032,0.05)
input.visible(0) #Only visible when in type mode
def onChat(e):
updateChat(e.client+': '+e.chat)
viz.callback(CHAT,onChat)
talking = False
def onKeyDown(key):
global talking
if key == 'y' and not talking: # Start talking mode
talking = True
input.message('> _')
input.visible(1)
elif key == viz.KEY_ESCAPE and talking: # Exit talking mode
talking = False
input.visible(0)
return True
elif talking and key == viz.KEY_RETURN: # Send message
talking = False
viznet.server.send(CHAT,client='SERVER',chat=input .getMessage()[2:-1])
input.visible(0)
# Update display with our message
updateChat('SERVER'+': '+input.getMessage()[2:-1])
elif talking and key == viz.KEY_BACKSPACE: # Delete a character
if len(input.getMessage()) > 3:
input.message(input.getMessage()[:-2]+'_')
elif len(key) > 1: # Handle special keys
return False
elif talking and 32 <= ord(key) <= 126: # Input message
input.message(input.getMessage()[:-1]+key+'_')
viz.callback(viz.KEYDOWN_EVENT,onKeyDown,priority=-6)
CLIENT CLIENT CLIENT CLIENT
import viznet
import vizinfo
objects = {}
SEND_UPDATE_TIMER = 1
SERVER_NAME=viz.input('Enter Server Name')
while not viznet.client.connect(SERVER_NAME,port_in=14951,po rt_out=14950):
if viz.ask('Could not connect to ' + SERVER_NAME + ' would you like to try another?'):
viz.quit()
break
objectList = ['duck.wrl','logo.wrl','male.cfg','female.cfg']
obj_choice=viz.choose('Connected. Select your character',objectList)
def mytimer(num):
if num == SEND_UPDATE_TIMER:
ori= viz.get(viz.HEAD_ORI)
pos = viz.get(viz.HEAD_POS)
viznet.client.sendAll(UPDATE,client=viz.getCompute rName
(),object=obj_choice,pos=pos,ori=ori)
viz.callback(viz.TIMER_EVENT, mytimer)
viz.starttimer(SEND_UPDATE_TIMER, .05, -1)
def update(e):
if e.client != viz.getComputerName():
try:
objects[e.client].setPosition(e.pos)
objects[e.client].rotate(e.ori)
except KeyError:
objects[e.client] = viz.add(objectList[e.object],scale=[2,2,2],pos=e.pos,euler=e.ori)
objects[e.client].tooltip = e.client
viz.callback(UPDATE,update)
def client_disconnected(e):
objects[e.client].remove()
del objects[e.client]
viz.callback(CLIENT_DISCONNECTED,client_disconnect ed)
def onStopServer(e):
print 'Disconnected from server'
viz.quit()
viz.callback(viznet.SERVER_DISCONNECT_EVENT,onStop Server)
import viztip
tth.start()
tth.setDelay(0)
text = viz.addText('\n\n\n\n',viz.SCREEN)
text.fontSize(25)
text.translate(.05,.08)
input = viz.addText('> _',viz.SCREEN)
input.fontSize(25)
input.translate(.032,.05)
input.visible(0)
def onChat(e):
talking = False
def onKeyDown(key):
global talking
talking = True
input.visible(1)
talking = False
input.visible(0)
return True
talking = False
viznet.client.sendAll(CHAT,client=viz.getComputerN ame(),chat=input.getMessage()[2:-1])
input.visible(0)
elif len(key) > 1:
return False
Old 05-11-2007, 03:50 PM
Can you repost the code using the special code tags?
HTML Code:
[code]insert code here[/code]
This will preserve the indentation in the code.
Old 05-11-2007, 04:03 PM
No need for the chat management code, I experimented without it.
import viznet
view.lookat(0,0,10)
objects = {}
def update(e):
	try:
	except KeyError:
		objects[e.sender] = viz.add(objectList[e.object],scale=[2,2,2],pos=e.pos,euler=e.ori)
import viztip
tth.start()
tth.setDelay(0)
import viznet
import vizinfo
objects = {}
while not viznet.client.connect(SERVER_NAME,port_in=14951,port_out=14950):
        viz.quit()
        break
def mytimer(num):
        viznet.client.sendAll(UPDATE,client=viz.getComputerName(),object=obj_choice,pos=pos,ori=ori)
def update(e):
        try:
        except KeyError:
#The client_disconnected function performs some simple cleanup when another client disconnects,
#and the onStopServer function closes the client.
viz.callback(CLIENT_DISCONNECTED,client_disconnected)
    viz.quit()
viz.callback(viznet.SERVER_DISCONNECT_EVENT,onStopServer)
import viztip
tth.start()
tth.setDelay(0)
Old 05-11-2007, 04:25 PM
I just tested your script here, running one server with two clients and it worked fine. You said that server to client communication does not work. Have you tried a simple viznet example that does not use sendAll, to make sure that this is not a problem with your network setup?
I've included a very basic viznet example. In this example, whenever a client presses the spacebar their background color should change. Also, the server will print out a message every time a client connects/disconnects. If this does not work then there might be a problem with your network setup.
import viznet
#Create custom event IDs
CLIENT_KEYDOWN = viznet.id('ClientKeyDown')
SET_CLEAR_COLOR = viznet.id('SetClearColor')
#Start server
viznet.server.start()
colors = [viz.RED,viz.BLUE,viz.BLACK,viz.ORANGE,viz.YELLOW,viz.GREEN,viz.GRAY]
curColor = 0
#When client connects, send them current color
	viznet.server.sendClient(e.sender,SET_CLEAR_COLOR,color=colors[curColor])
	print '** Client joined:',e.sender
viz.callback(viznet.CLIENT_CONNECT_EVENT,onStartClient)
#Print out when client leaves
	print '** Client left:',e.sender
viz.callback(viznet.CLIENT_DISCONNECT_EVENT,onStopClient)
#When client presses space key, change color and notify all clients
def onKeydownClient(e):
	global curColor
	if e.keydown == ' ':
		curColor = (curColor + 1) % len(colors)
		viznet.server.send(SET_CLEAR_COLOR,color=colors[curColor])
viz.callback(CLIENT_KEYDOWN,onKeydownClient)
import viznet
#Connect to server
viznet.client.connect(viz.input('Enter Server Name'))
#Send message to server when space key is pressed
vizact.onkeydown(' ',viznet.client.send,CLIENT_KEYDOWN,keydown=' ')
#Change color on server event
def onClearColorClient(e):
	viz.clearcolor(e.color)
viz.callback(SET_CLEAR_COLOR,onClearColorClient)
#Print out message if disconnected from server
	print '** Disconnected from server'
viz.callback(viznet.SERVER_DISCONNECT_EVENT,onStopClient)
Old 05-11-2007, 05:06 PM
If it works on your side, then it definitively is something with my network config.
I'll keep on playing around.
Patrick
Old 07-04-2013, 10:11 AM
iva iva is offline
Okay, this is a 6 years old post, but I have had the same problem already twice, so next time when I google for the solution, I will find this post. I don't know if this would solve OP's problem, but I had the same situation, communication worked from client to server, but server to client never worked. It turns out, if I use server's machine name instead of server's IP address, miraculously everything started to work.
