Old 12-11-2006, 01:29 PM
kgarr kgarr is offline
Quad Buffer
I don't know if this is a Vizard issue or not. Our video card (a wildcat VP990 Pro) died so we switched over to a machine with a Quadro 1300. The video card has the sync output but I can't seem to get the quad buffered stereo to work.
Any suggestions?
Old 12-11-2006, 01:42 PM
Have you tried calling viz.go(viz.QUAD_BUFFER).
Old 12-11-2006, 01:46 PM
yes I have, it worked fine on our previous machine. I am assuming it is some setting on the nvidia card.
Old 12-11-2006, 02:21 PM
When you first run scripts with viz.go(viz.QUAD_BUFFER) does it print "Visual Choser: cannot apply settings" or something like that.
Old 12-11-2006, 02:28 PM
The error I get is:
Producer::VisualChooser: the requested visual is not available, try relaxing attributes
It gives that error 3 times in a row.
Old 12-11-2006, 02:47 PM
Yeah, this sounds like a nVida driver/settings fix. Assuming you have installed the nVida Quadro drivers, check the nVida control pannel for a quad buffering setting.
