Old 10-20-2006, 08:00 AM
Joran Joran is offline
Send a message via Yahoo to Joran
Post clip with frustum problem
I have a problem when using the Window.clip command in combination with Window.frustum. When I call the clip command after I have set the frustum, it will change the frustum settings. I think this is not the correct behavior. I think it should only update the near and far clipping plane and keep the other frustum values (update them so that they have the same effect).
Example script:
viz.add('tankmaze.wrl')
viz.MainWindow.frustum(0.0, 0.52632, -1.0, 0.39474, 1, 3000)
def onKeyDown(key):
	if key==' ':
		viz.MainWindow.clip(0.1,10000)
viz.callback(viz.KEYDOWN_EVENT,onKeyDown)
Greetings, Joran.
Old 10-20-2006, 11:16 AM
Thanks for the bug report. This will be fixed in the next beta release.
