flockOfBirds events
Hello everybody,
I found that Vizard is so simple in working with FlockOfBirds trackers. Now I woudl ask you for how can I event mapping generated by the FOB? I followed the example in the manual that manages the FOB to move the head position. I would use it to change a 3D cursor represented by a sphere. Where can I find an example? What is the event releted to the FOB? I found that I can map viz.TRACKER but I think this is not the right event. Isn't it? Thank you so much. Giancarlo
If you want a model, like a sphere, to take on the postion and orientation of a bird, use the <VizNode>.link( sensor ) command.
sensor = viz.add('flockofbirds.dls');
cursor = viz.add( 'ball.wrl' )
cursor.link( sensor )
Paul Elliott WorldViz LLC |
Thank you very much your help will be very usefull but I was asking for is if there is any kind of....
viz.callback(????Events FOB???, functionHandler) related to this device. Thank you so much Giancarlo
There is no event functionality for this sensor. As an alternative, set up a timer that monitors the sensor data and calls a function when the data changes to an event worthy state.
