Old 06-01-2006, 01:50 PM
paulpars paulpars is offline
multiple timers
i have two timers, one that listens for certain keyboard input, and another that makes a person walk around in my world. I want the first one to be always on, but is there a way to make the second one start after a certain elapsed time, say 5 seconds or so? here's what my timer function looks like:
def mytimer(num):
	if num == 0:
		brake = 0
		if viz.iskeydown(viz.KEY_TAB):
			brake = 1
		if viz.iskeydown(viz.KEY_UP) and brake != 1:
			view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
			car2.translate(0,0,MOVE_SPEED*viz.elapsed(),viz.RELATIVE)
		elif viz.iskeydown(viz.KEY_DOWN):
			view.move(0,0,-MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
			car2.translate(0,0,-MOVE_SPEED*viz.elapsed(),viz.RELATIVE)
		if viz.iskeydown(viz.KEY_RIGHT):
			view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
			view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
		updatecar()
	# puts the walker on the screen
	if num == 1:
		walker.visible(viz.ON)
		global walkerX, walkerY, walkerZ, walkerAngle
		walker.rotate(0,1,0,90)
		# calculate components of motion w.r.t X and Z axis
		walkerZ = walkerZ - 0.00002 * math.sin(math.radians(walkerAngle))
		walkerX = walkerX + 0.00002 * math.cos(math.radians(walkerAngle))
		# move the walker
		walker.translate(walkerX,walkerY,walkerZ,viz.RELATIVE)
viz.starttimer(1,0,viz.PERPETUAL)
Old 06-02-2006, 06:55 AM
halley halley is offline
A timer starts whenever you call viz.starttimer(), so your goal is to decide when it's appropriate to make that call.
Something like this sketch (this is not tested code):
timer_one = False
def mytimer(num):
	if num == 0:
		if not timer_one and viz.get(viz.FRAME_TIMESTAMP) > 5.0:
			timer_one = True
			viz.starttimer(1, 0, viz.PERPETUAL)
		# do other timer-zero stuff
	if num == 1:
		# do other timer-one stuff
viz.callback(viz.TIMER_EVENT, mytimer)
viz.starttimer(0, 0.01, viz.FOREVER)
[ e d h a l l e y ]
I'm just a user, not a representative of WorldViz. Hope I've been helpful.
Old 06-02-2006, 09:12 AM
error
when I try to run that I get this error:
AttributeError: 'module' object has no attribute 'FRAME_TIMESTAMP'
Old 06-02-2006, 09:43 AM
You can also use the Python time module.
import time
#Gives number of seconds since program start
print time.clock()
Paul Elliott
WorldViz LLC
Old 06-02-2006, 10:12 AM
ok that seems to work fine, thanks!
