  #31
Old 03-20-2006, 02:22 PM
Ok, everything works great so far. The only problem is that I am getting some kind of traceback error.
  File "Test2WithEyeAdjustment.py", line 185, in mytimer
    avatar = avatars[nextAvatar]
IndexError: list index out of range
This occurs whenever I shoot an avatar and he disappears. When I double click on the error it highlights:
def mytimer(num):
	global avatars
	if num == ANIMATION:
		#Calculate elapsed time since last update
		elapsed = viz.elapsed()
		#Update each active ball
		for bullet in bullets:
			if bullet.active:
				#Move the ball and check if it has collided with any objects
				MoveBullet(bullet,elapsed)
	elif num == START_AVATAR:
		global nextAvatar
		#Get the next available avatar and start it
		#favatar = favatars[nextAvatar]
		walkAvatar(avatar)
		#walkAvatar(favatar)
		nextAvatar = (nextAvatar + 1) % NUM_AVATARS
		viz.starttimer(START_AVATAR,TIME_BETWEEN_AVATARS)
#Create callbacks for timer events
When I shoot the avatars, this function is called:
def shootBullet():
	global nextBullet
	#find the next available ball to shoot
	bullet = bullets[nextBullet]
	nextBullet = (nextBullet + 1) % NUM_BULLETS
	#Calculate the vector of the ball based on the mouse position
	pos = viz.mousepos()
	bulletvector = viz.screentoworld(pos[0]+0.25,pos[1]) #Need to account for stereo
	bullet.vector = viz.Vector(bulletvector[3]-bulletvector[0],bulletvector[4]-bulletvector[1],bulletvector[5]-bulletvector[2])
	bullet.vector.normalize()
	bullet.vector *= BULLET_SPEED
	#translate the bullet to the head position
	bullet.translate(viz.get(viz.HEAD_POS))
	#make the bullet visible
	bullet.visible(viz.ON)
	#mark the bullet as active
	bullet.active = 1
def MoveBullet(bullet,elapsed):
	#get the bullet's current position
	pos = bullet.get(viz.POSITION)
	#calculate the balls future position based on it's velocity
	futurePos = pos + (bullet.vector * elapsed)
	#Check if bullet intersected with anything
	info = viz.intersect(pos,futurePos)
	if info.intersected:
		if info.object in avatars:
			#viz.starttimer(FREEZE_AVATAR,info.object.getduration(7)-0.1)
			WaitThenFreeze = vizact.sequence( vizact.waittime(info.object.getduration(7)-0.05), vizact.speed_node(0) )
			info.object.execute(7)
			info.object.clear(viz.ALL)
			info.object.clear(viz.CURRENT_ACTION)
			info.object.add(WaitThenFreeze) #Add the action to the avatar
			RemoveAvatarAction = vizact.call(RemoveAvatar,info.object)
			info.object.add(RemoveAvatarAction) #Add action to remove avatar
		bullet.visible(0)
		bullet.active = 0
	#Update balls positions
	bullet.translate(futurePos.get())
#Shoot a ball whenever left mousebutton is clicked
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,shootBullet)
What does the error mean? Can it be fixed
Old 03-20-2006, 03:17 PM
That means you are trying to index into the avatar list with a value greater than the size of the list. Are you deleting items from the avatar list after you create it? If so then you need to change the way you increment to the next avatar:
nextAvatar = (nextAvatar + 1) % len(avatars)
Old 03-21-2006, 10:26 AM
I'm still getting the same error. I'm not sure what is causing it. When a bullet "hits" or intersects an avatar, the following code is called:
			WaitThenFreeze = vizact.sequence( vizact.waittime(info.object.getduration(7)-0.005), vizact.speed_node(0) )
The RemoveAvatar function is:
def RemoveAvatar(avatar):
	avatar.visible(0) #Hide avatar
	avatar.speed(1) #Restore speed
	avatars.remove(avatar) #Remove from list
	dead_list.append(avatar) #Add to dead list
I tried using the len(avatars) modulus division but it still gives me the same traceback error.
I also tried:
		if len(avatars) != NUM_AVATARS:
			avatar = dead_list[nextAvatar]
			nextAvatar = nextAvatar + 1 % len(dead_list)
		walkAvatar(avatar)
but that didn't work either.
Old 03-21-2006, 11:47 AM
New question, similar problem. I have now been told that the avatars must appear with different faces, based on an input. Here is what I have done so far:
#define a choice variable
choice = viz.input("Please input the condition:")
global facepic
if choice == 1:
	facepic = 'biohead_talk.vzf'
	facepic = 'morph_head.vzf'
#Create six avatars
for i in range(NUM_AVATARS):
	newX = -10 * math.sin(theta * i)
	newZ = 10 * math.tan(theta * i)
	if newZ <=10:
		newZ = -15
	#print i,"\t\t\t\t\t",newX,"\t",newZ
	male = viz.add('male.cfg')
	male.face(facepic)
	male.scale(1.25,1.25,1.25)
	male.translate(newX,-10,newZ)
	avPos = male.get(viz.POSITION)
	print 'original avatar position', avPos
	male.rotate(180,0,0)
	avatars.append(male) #Save avatar in list
Now, when I shoot the avatars, they fall and disappear, as planned. The problem I'm having is that the face still stays on the screen.
Here is the code for removing the avatars once shot:
		print 'intersect point is',info.intersectPoint
Is there a reason why the face stays floating in the air. I'm assuming it should disappear with the body. Please help.
Old 03-21-2006, 11:57 AM
Try incrementing the to the next avatar before you access it:
The face and body of the avatar are two separate objects, so you need to also hide the face when you hide the avatar.
Old 03-30-2006, 02:07 PM
Earilier in this forum, when we discussed the crosshair, you mentioned that we shouldn't be using objects that are attached to the screen when using stereo. I spoke to Mattias this weekend at the VR conference in Alexandria, VA and he mentioned that if we use a 3d object, we would probably be able to fix the problem of the bullets (mentioned in above posts) without having to change the IPD. Is this the case. Is there some way of making a "3d crosshair" that will accurately point to where the bullet would go? If so, do you have any ideas on how this can be implemented? I was thinking of making a vector that would match the vector of the bullet and place an icon (crosshair) at some point on the vector, in 3d, to show an aiming point. How does this idea sound? Can it be done? Please help.
Below is the code I have for the bullet so far.
def shootBullet():
	global nextBullet
	bullet.active = 1
	global avatarsHit
		avatarsHit = avatarsHit + 1
		print 'Avatars hit: ', avatarsHit
		bullet.visible(0)
		bullet.active = 0
Old 03-30-2006, 02:19 PM
Yes, this is how most people implement crosshairs for stereo viewing. Here is a sample script that will place a crosshair 0.1 meters in front of the user.
viz.go(viz.STEREO)
viz.add('tut_ground.wrl')
viz.clearcolor(viz.GRAY)
crosshair = viz.add(viz.TEXQUAD)
crosshair.texture(viz.add('crosshair.png'))
crosshair.scale(0.01,0.01,0.01)
viz.mouse(viz.OFF)
def ontimer(num):
	line = viz.screentoworld(viz.mousepos())
	v = viz.Vector(viz.get(viz.HEAD_POS))
	dir = viz.Vector(line[3:]) - viz.Vector(line[:3])
	dir.normalize()
	dir *= 0.1 #Place crosshair 1/10th meter in front of user
	v += dir
	crosshair.translate(v.get())
	crosshair.rotatequat(viz.get(viz.VIEW_QUAT))
viz.callback(viz.TIMER_EVENT,ontimer)
viz.starttimer(0,0,viz.FOREVER)
Old 04-04-2006, 10:40 AM
Ok, I implemented the crosshair as you said, however I'm still getting an offset between the bullet and the crosshair. Is there anyway to correct this now that I am using the "3d" version of the crosshair? I've attached a copy of the code.
Old 04-04-2006, 11:14 AM
I tried your script but I didn't see any bullet. I've modified my previous code so that it shoots a bullet from the center of the viewpoint towards the direction of the crosshair. There will always be an apparent offset between the crosshair and the bullet due to binocular vision.
viz.go(viz.STEREO)
viz.mouse(viz.OFF)
def ontimer(num):
	dir.normalize()
	v += dir
bullet = viz.add('white_ball.wrl')
def shoot():
	pos = viz.Vector(viz.get(viz.HEAD_POS))
	dir = viz.Vector(crosshair.get(viz.POSITION)) - pos
	dir.normalize()
	dir *= 10
	bullet.translate(pos.get())
	bullet.goto((pos+dir).get(),3)
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,shoot)
Old 04-04-2006, 11:46 AM
I apologize. I think I sent you something I was working on earlier but I corrected it. I still get the same behavior. Would you mind taking a look at this one and let me know if there is something wrong? Thanks
Old 04-04-2006, 12:31 PM
In both calls to viz.screentoworld you are adding an offset to the x position. You don't need to do this when using a 3D cursor. Also, after adding the cursor you should disable collisions on it so the bullet does not hit it.
crosshair.disable(viz.COLLISION)
