Old 03-05-2006, 05:17 PM
cantwelljm cantwelljm is offline
Question Glass (transparent materials)
Hi
I have created a building in 3ds Max. When I import it into vizard the glass in the windows disappears. If a material is transparent or semi-transparent does vizard then treat it as invisable?? Is there any way of showing convincing looking glass in vizard??
Old 03-08-2006, 02:39 PM
tobin tobin is offline
Material opacity should come through in the 3DS format but I'll have to verify that. It certainly does in other formats.
A good technique, though, to give the impression of glass it to use a texture that has an alpha transparency layer. For the bitmap, add some scratches or a little dirt.
Finally, if you're window glass is a separate object, say "pane", then you can call worldObject.alpha(0.5, "pane") and it'll search through and set any sub-objects named "pane" to be 50% transparent.
