Old 02-21-2006, 12:39 PM
Multiple Viewports in Vizard, Utilizing keyboard callback
I tried to create 4 viewports on the screen at once.
I have the main viewport, and then
3 viewports on the side.
I used a simple keyboard callback function to
turn the viewports on and off.
Below is the code I am using.
Everything works fine up until I press a,s, or d 4 times. After
the fourth press, Vizard will crash.
Is this just sloppy implementation on my part?
Also, the next thing I will be working on when these
viewports stop crashing is making the viewport
lock in on whatever the previous view was.
Can I simply set the
viewpoint of the window
to the main cameras view
and update it every time there
is a keyboard event (which in my
case will only make the viewports
turn on and off).
~~Thanks,
George
#~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~Keyboard
def mykeyboard(key):
	view = viz.add(viz.VIEWPOINT)
	if key == 'a':
		window1.visible(viz.TOGGLE) # Hide the window
	elif key == 's':
		window2.visible(viz.TOGGLE) # Hide the window
	elif key == 'd':
		window3.visible(viz.TOGGLE) # Hide the window
#~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~Objects
viz.add('outersphere.IVE')
viz.add('innersphere.IVE')
viz.add('plane.IVE')
window1 = viz.add(viz.WINDOW)
window1.position(0,1)
window2 = viz.add(viz.WINDOW)
window2.position(0,0.25)
window3 = viz.add(viz.WINDOW)
window3.position(1,0.25)
#~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~Callback
viz.callback(viz.KEYBOARD_EVENT,mykeyboard)
Old 02-21-2006, 01:52 PM
Which version of Vizard are you using? There was a bug that would cause a crash when adding a certain amount of viewpoints, but it should be fixed in the latest version.
I've modified your script to update the viewpoint of each window when the corresponding key is pressed. The only "sloppy" thing about your script is that you are adding a new viewpoint each time a key is pressed. The the script below creates a viewpoint for each window during startup, and just modifies the existing viewpoint in the keyboard callback. Let me know if this doesn't help:
	if key == 'a':
		view1.translate(mainView.get(viz.HEAD_POS))
		view1.rotatequat(mainView.get(viz.HEAD_QUAT))
	elif key == 's':
		view2.translate(mainView.get(viz.HEAD_POS))
		view2.rotatequat(mainView.get(viz.HEAD_QUAT))
	elif key == 'd':
		view3.translate(mainView.get(viz.HEAD_POS))
		view3.rotatequat(mainView.get(viz.HEAD_QUAT))
view1 = viz.add(viz.VIEWPOINT)
window1.viewpoint(view1)
view2 = viz.add(viz.VIEWPOINT)
window2.viewpoint(view2)
view3 = viz.add(viz.VIEWPOINT)
window3.viewpoint(view3)
mainView = viz.get(viz.MAIN_VIEWPOINT)
Old 02-21-2006, 05:56 PM
Thanks a lot.
I modified it slighty and kept it from crashing again.
I believe we are using an earlier version at our school.
A few decimal places behind the one you currently offer.
That probably accounts for the error. And since I was
adding a new viewport each time, I can see how it could
compound and create some problems after the 4th instance.
Thanks again,
George
