Old 02-19-2020, 08:54 AM
josephredfern josephredfern is offline
Rotating objects about a point
I have have a list of nodes (returned from viz.addChild). I wish to rotate all of these models about the Y axis of a single point (specifically, 180 degrees). What is the best way to do this? I've tried using setCenter (setting the new center to the position about which I wish to rotate each model) in combination setEuler without success...
Thank you,
Joe
Old 02-19-2020, 10:02 PM
You can parent all the nodes to a group node and set its position to the point you want the nodes to rotate around.
Old 02-20-2020, 01:15 AM
Hi Jeff,
Thank you for your reply.
I've ended up doing the following:
* Create a group
* Set center (not position) of group to rotation point
* Add objects to scene (viz.addChild), specifying position and setting parent to the newly created group
Setting the position of the group rather than the centre made the models be added relative to the new position -- unless I was missing something.
Rotating an object around a point BWhiteDerby Vizard 1 08-25-2015 04:37 PM
joints/spin objects rmcconnell11 Vizard 0 02-17-2014 07:13 AM
Lightwave objects rotation problem hosier Vizard 6 02-13-2009 12:04 PM
