Old 01-31-2019, 09:42 PM
Vishav Vishav is offline
Vizard stopped working
I built an application using vizard with incorporated eye-tracking in it. This application consisted of 48 objects and an avatar and it has 48 trials. But it is stopping in between (every time I run it; it used to stop after few trials) with error attached as a snapshot. Why this is happening?
Any suggestions to handle this!
Old 02-03-2019, 06:46 AM
Did you press the button to send the error report? That may help but it will likely require some debugging and narrowing down the code to determine where it breaks.
Old 02-04-2019, 11:41 PM
Yes I pressed Send button
Old 02-05-2019, 09:23 PM
I'll check with a developer and see if the report gives some indication of the issue.
Current working directory in Vizard Executable kevin Vizard 3 06-16-2011 12:31 PM
win32ui winviz.exe has stopped working TarkaDahl Vizard 3 08-10-2010 06:19 PM
