Old 12-07-2017, 09:32 AM
Vishav Vishav is offline
How to disable sound in Vizard code
Dear all,
Is there any way to disable sound of code in vizard without commenting it.
Old 12-07-2017, 11:38 PM
I didn't quite understand the question. Can you explain a bit more what you're trying to do?
Old 12-08-2017, 05:28 AM
My code consists of multiple speech and sound files. I need to recheck my code again and again. So i want to disable sound without removing or commenting out the code.
Old 12-09-2017, 10:47 PM
There is not a command to disable all sounds, you would have to disable each one individually.
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 05:30 PM
3D sound in vizard virtmeg Vizard 1 01-10-2005 10:06 AM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 11:52 AM
