Old 12-05-2017, 07:13 AM
Vishav Vishav is offline
Error in file opening Vizard
Dear all,
I am getting this error in my code when i am opening file in append mode:
File "C:\Program Files\WorldViz\Vizard5\python\viztask.py", line 752, in updateAndKillOnException
return self.update()
File "C:\Program Files\WorldViz\Vizard5\python\viztask.py", line 719, in update
val = self._stack[-1].send(sendData)
File "DFI_Snacks.py", line 50, in task1
IOError: [Errno 22] invalid mode ('a') or filename: '<built-in function id>_experiment_data.txt'
My Source Code:
global experiment_data
os.chdir(r'D:\PhD\Study-I_Part_I\My_Programs\DFI\Participant_Data')
filename=str(id) +'_experiment_data.txt'
experiment_data = open(filename,'a')
print str(id)
I am getting exporting id value from other code
Please help me in it.
Old 12-06-2017, 12:33 AM
It looks like the file is not found. Does the following work?
directory = r'D:\PhD\Study-I_Part_I\My_Programs\DFI\Participant_Data'
filename = str(id) + '_experiment_data.txt'
filepath = os.path.join(directory, filename)
experiment_data = open(filepath,'a')
Old 12-06-2017, 06:48 AM
Same error is coming with code suggested by you.
I will explain it
I have one file called Parent in which i created file experiment_data having write mode using code.
experiment_data = open(str(id) + '_experiment_data.txt','w')
data = " Participant ID: %s\tParticipant Name: %s\tAge: %s\tGender: %s\n\n" % (id,Name,Age,gender)
experiment_data.write(data)
After that i made a child code to which i passed id variable value to child using code
id=id
myVars = {'id':id}
exec(open('DFI_Snacks.py').read(), myVars)
Then I open experiment_data file in child code matching with id value in append mode using code
This error is coming when Parent code import child code. I don't know where i am going wrong.
Old 12-06-2017, 11:09 AM
File Handling
If i open file every time i need to write data then this error not comes but then new problem came that is infobox.remove() is not working. Adding snapshot for reference.
Source Code:
if radio1.get() == viz.DOWN:
infoBox.remove()
score=0
os.chdir(r'D:\PhD\Study-Click image for larger version
experiment_data = open(str(id) + '_experiment_data.txt','a')
feedback = viz.addText('You are doing Great!',viz.SCREEN)
Old 12-07-2017, 09:53 PM
I figured it out... Thanks
.wrl File in Vizard Hitesh Vizard 2 07-02-2015 09:43 AM
Converting .blend file in .osgb or any vizard supported file Hitesh Vizard 0 07-02-2015 01:31 AM
Vizard .exe file doesn't load (Vizard 3) Saule Vizard 4 02-05-2014 06:01 AM
Interaction of vizard objects with an imported obj file sunil.nair Vizard 2 10-09-2013 02:08 PM
