Old 04-06-2017, 05:26 PM
Canucks Canucks is offline
Importing from Blender issue
I exported my design as obj file. Here is the render view. Then when I try to run my obj file in Vizard, its dark and looks horrible. I attached the screen shot. What am I doing wrong?
ID:	928   Click image for larger version
Old 04-06-2017, 11:39 PM
What is the code you are using to load the model in Vizard? I'm not sure if we have any experience with the Blender to obj workflow. You might try exporting to another format such as collada or fbx and see if the results are better.
Old 04-24-2017, 11:21 AM
I tried with both FBX and DAE . Still shows no texture and it's black and white. When I added a box to the scene by box=vizshape.addBox() and it shows the box in gray as well. what should I do
Old 04-26-2017, 12:11 AM
If you import the model that you exported from Blender back into Blender does it have textures?
blender
Regarding 3D Depth(immersive) issue with the IPD value during rendering at runtime. rajnishv Vizard 1 07-15-2016 06:04 AM
Applying textures to objects made in Blender andrewjworz Vizard 0 04-21-2011 07:15 AM
Vizard and blender 3d amartin7211 Vizard 0 11-12-2010 08:56 AM
Importing from Blender and getting "real" sizes for models? tmcw Vizard 1 03-19-2007 10:37 AM
