Old 03-22-2017, 12:26 PM
mihirradia mihirradia is offline
Low resolution second image.
Hi Jeff,
I am using zSpace system and using Vizard 5.7. The problem that I have is when I run the program I see 2 images,where the 2nd image is in a low resolution image. I have attached the images about my problem for your better understanding.
Please let me know what might be the cause of this problem.
Thanks in advance.
Regards,
Mihir
ID:	924   Click image for larger version
ID:	925   Click image for larger version
ID:	926   Click image for larger version
Old 03-23-2017, 02:58 AM
Do you see this issue when you run zspaceExample.py (File > Quick Open: Type zspaceExample)? If so, does this type of issue occur with the demo application provided by zSpace?
Old 03-23-2017, 04:20 PM
HI Jeff,
Yes, when I run the "zspaceExample.py" I see the low resolution second image and also with the demo application provided zSpace. Do you know what might be causing this error?
Old 03-24-2017, 12:06 AM
I'm not sure, it maybe related to a 3D setting for the graphics card.
Old 03-29-2017, 12:22 PM
Hi Jeff,
I tried working with different graphics card settings, but still I see the ghost image. Do you think it might be problem with the Vizard?
wrong background color in interlaced stereo image rlh001 Vizard 4 09-25-2013 05:21 PM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 07:17 AM
3-D image in Powerwall using OpenGL c++ program blessonisaac Plug-in development 0 02-01-2012 10:22 AM
View an image on the Fakespace HMD roman_suvorov Vizard 16 05-23-2008 08:51 AM
