Colors
I was working with Vizard and I tried to change the color of some objects throught the script but I am not sure how to name some colors. Is there any link where I could find the way Vizard labels hues? Thanks, Vinicius |
Vizard uses RGB to specify color values. Each component is specified with a value between 0 and 1. Here is a link to the Wikipedia page on RGB: http://en.wikipedia.org/wiki/RGB |
Thanks, I've figured that out already. My problem is that sometimes colors have names like SKYBLUE and I don't know how exactly the other RGB colors are called.
Vizard defines some common color values. Here are the names and values: Code:
WHITE = (1,1,1) BLACK = (0,0,0) GRAY = (0.5,0.5,0.5) RED = (1,0,0) GREEN = (0,1,0) BLUE = (0,0,1) YELLOW = (1,1,0) ORANGE = (1,0.5,0) PURPLE = (0.5,0,0.5) SKYBLUE = (0.5,0.5,1) |
Thanks!
Vinicius |
Hi, I have a further question. How do I map a color in Vizard, like (0.5,0.5,0.5) gray, to a color represented by 8-bit? Is it (128,128,128) in the example?
Yes, the following code will apply that color to a box:
import vizshape
box = vizshape.addBox(pos=[0,1.8,4])
vizact.onkeydown(' ',box.color,[0.5,0.5,0.5])
That's very helpful. Thanks!
