Old 01-10-2017, 06:45 AM
rajnishv rajnishv is offline
Smile Regarding a 2 Walled(Left Wall n Right Wall) Projectn with Ground(Floor) Projectn
Hi Jeff,
I am developing a vizard demo,in which i have to achieve the following VR Corner Cave SetUp Topology.
1)I want my projections should be on the 2 walls (RIGHT wall and LEFT Wall) and also the GROUND(floor).
2)There are 4 PPT Cameras of which 2 cameras are installed at the above the corners of the LEFT wall and the RIGHT wall with 1 camera above at extreme top-left of the LEFT Wall and also 1 camera above at extreme top-right of the RIGHT wall.
To achieve:
I have achieved 2 walled projection,but i want projection on LEFT wall,RIGHT wall and also on the GROUND to give a actual feel and perpective of the VR Environment with full immersion.
Which setup or presets or any configuration do i have to choose from the vizconnect GUI to achieve the following setup with proper trackers configuartion?
PFA of the setup topology of what i have to achieve using Vizard.
Pls assist me further.
Waiting for your reply.
Old 01-25-2017, 12:28 AM
Hi Jeff,
Do i have to follow the same methodology as reply mentioned by you in my post in the below link ?
Post Link:
http://forum.worldviz.com/showthread.php?t=5783
Four Wall Cave using two client cluster JB_HP_Viz Vizard 3 05-13-2016 04:26 AM
setup two wall system with one single PC and one quadro graphics card vrmdl Vizard 11 05-29-2012 10:59 AM
