Old 11-04-2016, 02:43 PM
mihirradia mihirradia is offline
Matrix
I have loaded an object in the virtual environment. Now I want to know its 4x4 Homogenous Coordinate System and print the values in the Interactive window. How do I do that?
Thanks in advance.
Old 11-04-2016, 03:54 PM
Take a look at the node3D.getMatrix() command.
Old 11-05-2016, 08:17 AM
The command that you showed returns the transform of the object in the specified coordinate system. But, my goal is to find the 4X4 matrix of an object after loading it into the virtual environment. Can you provide me with an simple exam of how I can achieve that?
Old 11-05-2016, 08:20 AM
The command that you showed returns the transform of the object in the specified coordinate system.. But, my goal is to find the 4x4 matrix of the object after loading into the virtual environment and print those values. Can you provide me with a simple example of how it can be achieved?
I would be grateful if you could help me out.
Thanks in advance.
Old 11-07-2016, 03:53 PM
I'm not sure how this is different from getting the object's matrix in either the local, parent, or global coordinate system. Can you explain further what data you are looking for?
Old 11-08-2016, 09:03 AM
Hi Jeff,
I'm sorry I understood your point now. The command is exactly what I wanted. Could you provide me with an example of how can I obtain the 4x4 matrix using node3d.getmatrix().
Different projection matrix per viewpoint dcnieho Vizard 6 07-08-2016 05:06 AM
AR Marker Camera Matrix Transform Problem. pwsnow Vizard 11 06-30-2014 04:48 PM
Render Node View Matrix whaleeee Vizard 2 05-06-2013 09:26 AM
Projection Matrix (onto oblique near plane) andrewjworz Vizard 1 07-13-2012 09:10 AM
Matrix Transform and Bumpmap GiudiceLab Vizard 0 11-27-2009 12:42 PM
