Old 10-30-2016, 06:30 AM
bbb bbb is offline
viewpoint direction
Dear Jeff,
Is there a way to get participant's head direction in angles (degrees), which are not euler rotation ones, from some module or from the Oculus itself?
I'm basically trying to know the direction in degrees (not have to be degrees but i want to be able to understand there meaning) participant's are looking at and based on that i would like to know what they are looking at at the scene.
Thanks.
Old 10-31-2016, 12:38 PM
It sounds like you maybe looking for the yaw component of the euler angle. The following example shows the yaw, pitch, and roll values every frame:
import vizinfo
info = vizinfo.InfoPanel('Head Ori Data')
yaw = info.addLabelItem('yaw',viz.addText(''))
pitch = info.addLabelItem('pitch',viz.addText(''))
roll = info.addLabelItem('roll',viz.addText(''))
viz.add('dojo.osgb')
def updateInfo():
	ori = viz.MainView.getEuler()
	yaw.message('{:.2f}'.format(ori[0]))
	pitch.message('{:.2f}'.format(ori[1]))
	roll.message('{:.2f}'.format(ori[2]))
vizact.onupdate(0,updateInfo)
Old 11-01-2016, 02:49 AM
bbb bbb is offline
Hi Jeff,
I thought that myself but in an earlier post i asked you a question regarding the yaw of the euler angles and based on that i understood that i cannot use this so i guess i have some miss understanding, so i will ask again.
I asked you this: if i'm looking on the same thing from different positions in the scene, will i get the same euler angle? your answer was no. So, if i don't get the same euler angle for specific thing in the scene, how can i be able to conclude that from different positions i'm looking at the same thing, based on yaw?
I would appreciate a clarify and thank you for your efforts to solve my issue.
Old 11-01-2016, 06:39 PM
Vizard's built-in functions for determining what objects are in view include the window.pickRect command and window.pick command. You can use the viz.intersect command to see if a line segment intersects objects in the scene.
The yaw rotation of the viewpoint or tracker is not enough information to determine what object(s) are in view. You would also need the object and viewpoint positions to determine this. And if the user is looking up or down the object might be in line with their yaw rotation but not be in view. There is not a built-in function but you could probably use commands from the Python math library or Vizard's vizmat library to help do these calculations on your own. However I'm not sure why you would go this route since the pickRect and pick commands are an easy way to determine what objects are in view.
Old 11-02-2016, 05:54 AM
bbb bbb is offline
Dear Jeff,
Is there a way to get the nodes that in the center of the view from pick command? since it gave me an error of "object is not iterable" when trying to use this like pickRect command.
Here is a sample code:
def objectOfInterest(normPos):
picked=viz.MainWindow.pick(normPos)
for node in picked:
if node==triangle:
print "triangle view"
Thanks.
Old 11-02-2016, 02:33 PM
Here's an example that performs the pick command on the center of the window:
viz.clearcolor(viz.SLATE)
soccerball = viz.addChild('soccerball.osgb',pos=[-1,1.8,2])
basketball = viz.addChild('basketball.osgb',pos=[0,1.8,2])
volleyball = viz.addChild('volleyball.osgb',pos=[1,1.8,2])
crosshair = viz.addTexQuad(parent=viz.SCREEN,texture=viz.add('crosshair.png'),pos=[0.5,0.5,0])
def pickObject():
	node = viz.pick(pos=[0.5,0.5])
	if node == soccerball:
		print 'soccerball'
	elif node == basketball:
		print 'basketball'
	elif node == volleyball:
		print 'volleyball'
		print 'none'
vizact.onupdate(0,pickObject)
Also, the gazetime example script in this thread maybe helpful.
Regarding Viconnect viewpoint rajnishv Precision Position Tracker (PPT) 3 03-21-2017 12:03 AM
Regarding viewpoint with vizconfig,addFloatRangeItem&Storing viewpoint in PREFERENCES rajnishv Vizard 0 06-27-2016 04:57 AM
Draw Vector in viewpoint lookat direction Chrissy2009 Vizard 2 05-30-2009 01:50 AM
VRML Viewpoint error bstankie Vizard 1 03-11-2003 03:10 PM
