Old 09-16-2016, 09:13 AM
iva iva is offline
Missing letters
Hey guys,
I have the most bizzare problem which will, if nothing else, make you laugh.
some of my letters on the screen are missing. I am attaching a screenshot.
The strings get logged properly, so this is really just a rendering issue. The machine is Windows 10. The graphics card is Intel HD Graphics 530.
Help.
Old 09-20-2016, 08:12 AM
That is interesting. You could try updating the graphics drivers to see if it makes a difference. What version of Vizard do you have and could you post the vizinfo code that was run for the screenshot?
Old 09-20-2016, 10:03 AM
iva iva is offline
The driver is up to date. This is my code:
def showbuttons():
	global buttons
	global next
	global info
	global d1
	global task
	global logbutton
	global buttontick
	global lbutton
	logbutton= radios[task][d[task]][0]
	info = vizinfo.add( 'Where do you\n have to go?' )
	info.bgcolor(viz.BLACK,1.0)
	info.translate( [.98, .905] )
	buttons=[]
	for i in range(len(radios[task][d[task]])):
		#if radios[task][d[task]][i]!="none":
		buttons.append(info.add( viz.RADIO, task*10+d[task], radios[task][d[task]][i]))
	#next=info.add(viz.BUTTON_LABEL, "Next")
	lbutton.visible(1)
	buttontick=viz.tick()
	viz.callback(viz.BUTTON_EVENT,butts)
It is a bit messy out of the context unfortunately, but I don't do anything but append buttons to the vizinfo box. Also, the labels of the buttons get logged properly, so letters don't get lost in the process, it is just the rendering issue. Additionally, it works on my dev machine, just not on the lab machine... where it is important
I am using Vizard 4.09.0016.
Old 09-21-2016, 03:40 AM
Do you have the same issue running the following code?
import vizinfo
button1 = info.add( viz.RADIO,0,'straight')
button2 = info.add( viz.RADIO,0,'left')
button3 = info.add( viz.RADIO,0,'up')
button4 = info.add( viz.RADIO,0,'down')
button5 = info.add( viz.RADIO,0,'right')
button6 = info.add( viz.BUTTON_LABEL, 'Next')
Since the same code works on another machine it seems GPU/driver related. Try changing the performance settings mentioned in this article. You could also try rolling back the drivers to see if that makes a difference.
Access to individual letters in text3d pcatalano Vizard 1 09-15-2011 09:25 AM
.osg/.ive import - missing geometry & some textures jde Vizard 3 09-04-2009 03:18 PM
missing parts of head texture sjp Vizard 4 10-10-2006 01:10 PM
Stereo cubemap demo is missing some pictures Vbents Vizard 1 08-23-2006 05:42 PM
shadow.py and refract.py missing in trail 2.53 searsky Vizard 3 09-28-2005 08:38 AM
