Old 06-23-2016, 02:28 PM
mihirradia mihirradia is offline
Flickering of the z space environment when pressed with z space stylus
When I run the program UniIowamain1.py it opens up and I use the Z space stylus as a grabber to grab the object and move around in the Z-space environment. The problem that I'm facing is that sometimes when the stylus button is pressed it grabs the object and sometimes the flickering of the Z-space environment takes place. I do not understand the reason for flickering of the the Z-space.
With this I have attached the zip file that contains all the relevant documents to run the File UniIowamain1.py. I would be grateful, if you could help me out.
Old 06-27-2016, 04:21 AM
Do you have the same issue when running the zspaceExample.py script included with Vizard?
Old 06-27-2016, 02:18 PM
No, we do not have any issue.
Old 07-01-2016, 11:15 AM
Hi Jeff,
could you please look at the script that I have provided and tell us what exactly issue are we facing?
Old 07-01-2016, 11:47 AM
Sorry for not responding earlier but it's difficult to tell from what you've provided. For assistance with coding issues on the forum we require following the guidelines for posting Vizard code. Try reducing your code to the very minimum that reproduces the issue. Since the zspace example included with Vizard runs fine, you maybe to reproduce the issue using monitor/keyboard. In that case others can run and reproduce it easily as well. Also, take a look at the render stats while you're running your program. That can help with troubleshooting performance issues.
