Old 05-11-2016, 04:40 PM
helena35 helena35 is offline
Problems publishing as .exe file
Hi all,
I am a new Vizard user and i would be very thankful if you help with this issue. I have created a scene with a video mp4 inside. When I run the script, the video can be perfectly seen. I have plublished the script as an .exe file, and the .exe run perfectly in the computer in which I have generated it, but not in another computers (I have tried in two computers different to mine, both with windows 8)
Do you know which the reason can be?
Cheers
Old 05-13-2016, 03:40 AM
On the machines where it does not work, is the EXE running but without the video? You can enable 'Display console' during the publish process and see if any error messages are generated when running the EXE. Are you able to run the source files without a problem on those machines? You could install the Vizard Free version to test.
Old 05-14-2016, 03:10 PM
The .exe was running in other computers, but wihtout the video. I uploaded one file that was missing and now it works perfectly.
Thank you very much for your help
Helena
Vizard .exe file doesn't load (Vizard 3) Saule Vizard 4 02-05-2014 06:01 AM
still problem with data from .exe file Saz Vizard 1 07-10-2009 10:12 AM
problems with output to a text file within executable Saz Vizard 1 07-01-2009 11:01 AM
Problems loading WRL file DrunkenBrit Vizard 2 01-29-2009 12:58 AM
Problems loading dls file vnacooper Plug-in development 1 03-05-2007 09:26 AM
