Overriding Mouse Control
I want to manually set the location of the mouse cursor and use some other sort of input to control where the cursor is. How do I do that? Thanks, Vygreif |
The following script will manually move the mouse in a circlular motion at the center of the screen. The command to move the mouse cursor is win32api.mouse_event: Code:
import viz viz.go(viz.FULLSCREEN) import win32api import math angle = 0 def ontimer(num): global angle angle += 90 * viz.elapsed() x = (math.sin(viz.radians(angle)) * 0.3) + 0.5 y = (math.cos(viz.radians(angle)) * 0.3) + 0.5 x = int(65535*x) y = int(65535*y) #The mouse coordinates must be normalized from 0 to 65535. #The origin (0,0) represents the upper left corner of the monitor win32api.mouse_event(32769,x,y,0) viz.callback(viz.TIMER_EVENT,ontimer) viz.starttimer(0,0,viz.FOREVER) |
Looks good.
But where can I get win32api, when I try including it, it can't find the module. |
It's included in version 2.53 and above. If you don't want to upgrade send an email to lashkari@worldviz.com and I will send it directly to you. |
