Old 02-04-2016, 11:54 AM
jai jai is offline
Osg model loading error
Hello Jeff,
I have created a .ive n a .osgb model using open scene graph 3.2.0. I am getting loading error in vizard. Pls help
Old 02-04-2016, 09:52 PM
Can you describe further how you created the model? Vizard 5 is based on OSG 3.1.
Old 02-05-2016, 03:34 AM
jai jai is offline
Model is created using VPB in .ive and .osgb format.
I can upload or mail you the model. Since Other sample data models of OSG even 3.4.0 is successfully loaded in vizard , i expect this one to work.
Old 02-07-2016, 10:20 PM
jai jai is offline
Hello Jeff,
Can you guide me where to upload this model?
Old 02-08-2016, 03:53 AM
jai jai is offline
Hello Jeff,
I re built the model using osg 3.0.1 . It at least does not give any error but It is rendering the model as expected where as model is opening nicely in inspector. please help
Old 02-08-2016, 04:12 AM
jai jai is offline
please find the model file attached.
Old 02-10-2016, 05:46 AM
It looks like the scale of the model is off. Vizard's unit of measurement is the meter and the modeling software probably uses something else. If you look in Inspector, the bounding box of the model is around 5000 x 300 x 5000 meters. Try scaling the model down in Vizard:
sample = viz.addChild('sample.ive')
sample.setScale([0.001]*3)
import vizcam
vizcam.PivotNavigate(distance=10)
Old 02-11-2016, 02:59 AM
jai jai is offline
thanks a lot Jeff. It helped.
Old 02-21-2016, 09:33 PM
jai jai is offline
Hello Jeff,
Can we use all osgviewer controls from Vizard ? kindly help in this regard
Old 02-22-2016, 12:13 PM
Can you describe what you're trying to do?
Old 02-22-2016, 08:25 PM
jai jai is offline
Hello Jeff,
I have created one osga model using open scene graph. I use to run this model using osgviewer . Same model I can use in vizard also. But, osgviewer provides so many controls perspective view,lights etc. by default over the model ; Can I achieve all the controls of osgviewer in Vizard?
Old 02-22-2016, 09:23 PM
I'm not familar with osgviewer so am not sure if all the same controls are available. You can also browse the scenegraph and view the model in Inspector. Lights can be added in Vizard using a standard or vizfx workflow.
Old 03-30-2016, 03:32 AM
jai jai is offline
Hello Jeff,
I want to run *.osg file which is built on osg version 3.0 using vizard.
As , vizard is also built over osg version 3.1.
Can we view osg file using osg kind of viewer in wizard.
We donot want to add the object as 3d object in vizard for this.
Old 03-30-2016, 04:35 AM
jai jai is offline
jeff,
Actually i can see all include and lib directories of osg in vizard directory.
Now, can i say import osg or import osgViewer in vizard ??
if not then please help me how can i call osgviewer in vizard
regards
Jai
Old 03-30-2016, 11:18 PM
What functionality do you need from osgviewer and what is the result you are looking for?
Old 03-31-2016, 01:12 AM
jai jai is offline
Hello Jeff,
One objective is simply to visualize anything model / format compatible to osgviewer.
Secondly, to visualize the other applications built over osg 3.0 using vizard.
Old 04-04-2016, 01:43 AM
jai jai is offline
jeff,
please, help me in calling viewer from vizrard?
secondly, can we have all controls like osg in vizard using viz.go for example
flight mode, drive, terrain etc modes?
if not how to go around this??
Old 04-04-2016, 09:11 AM
Sorry, it's not possible to use osgviewer from within Vizard. Inspector is the tool that's included with Vizard for viewing Vizard compatible models and browsing the scenegraph.
I'm not sure what you're referring to by flight mode and drive. If you're looking for different navigation techniques in Vizard, take a look at the vizconnect transports.
Old 04-05-2016, 01:55 AM
jai jai is offline
Jeff,
We have purchased a license copy of vizard.
Can you give me your personal id or someone's id who can help me with my questions?
Jai
Old 04-05-2016, 10:17 AM
Yes, you can send an email to support@worldviz.com for further questions about this.
3ds Exported .IVE Model mirrors movement of Mainview Felix Vizard 9 05-18-2012 09:17 AM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
Loading morph mesh error. vEsotu Vizard 2 03-14-2009 06:29 PM
Error loading plugin djdesmangles Vizard 2 10-02-2008 07:13 AM
Error when loading a lot of avatars dan12345 Vizard 7 07-28-2008 04:24 AM
