Old 12-01-2015, 04:26 PM
szkuls szkuls is offline
Vizconnect grabber grab area
I am able to get the grabber tool working with vizconnect but the hotspot for grabbing an object seems to be the same size at the center or pivot of the object no matter how large or small the object is. For example here is a code snippet with two cubes. The one on the left is easily highlighted and grabbed where as the larger cube on the right can still be grabbed but is very difficult to see where the hand is or if you are close to the center of the cube to make the grab.
import vizconnect
import vizshape
vizconnect.go ('vizconnect_desktop.py')
scene = viz.addChild ('piazza.osgb')
smallBox = vizshape.addBox (size = (1,1,1))
smallBox.setPosition ([0, 1, 0])
bigBox = vizshape.addBox (size = (5,5,5))
bigBox.setPosition  ([6, 3, 0])
tool = vizconnect.getRawTool ('grabber')
tool.setItems ([smallBox, bigBox])
Is there a way to adjust the hotspot or collision/intersection area of the items that are set to grabbable? Ideally, I would like to have the bounding box be the intersection area for the the hand to grab.
Thanks!
Old 12-02-2015, 06:08 PM
Thanks for the example, I'll check with a developer about this.
Old 12-18-2015, 12:30 AM
The grabber tool intersection test is based on the distance to the center of the object. You can, however, modify the distance test used so that it works with the bounding box. The attached example should work, but this is not officially supported code.
grabber, tool, vizconnect
Zspace display in Vizconnect JB_HP_Viz Vizard 5 06-05-2015 04:28 PM
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 06:19 AM
delete hand in vizconnect rvenegas Vizard 4 06-05-2014 11:17 PM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 10:45 AM
Setting up a 'reaction area' Karthi Vizard 4 01-29-2004 05:39 PM
