Old 12-09-2015, 10:19 PM
Smile Is it possible to change the unit in Vizard
Is it possible to change the unit in Vizard into 25 cm or 10 cm ?
I want to match some certain coordinate which has a maximum range of 3 m
Old 12-09-2015, 10:36 PM
Vizard's unit of measurement is the meter, it can't be changed. I don't understand what you're trying to do.
Old 12-09-2015, 10:38 PM
You can convert the cm values to meters, for example 0.25 or 0.10
Old 12-10-2015, 08:34 AM
Smile
There is a demo on the Internet demonstrate the FAAST and Kinect, I want to expand the tracking range in Vizard software,
The Kinect can only track around 3.5 meter so it is very small area in Vizard
Old 12-14-2015, 05:10 AM
You can apply a scale to tracker movements. If you're using vizconnect, press the offsets button after adding the kinect tracker and enter scale values in the post scale fields.
Old 12-14-2015, 05:47 PM
how to change the scale to tracker movements if i am using VRPN plug in server ?
