Old 11-17-2015, 01:39 PM
lklab lklab is offline
How do IM\ make avatar textures two sided?
I created a 3d animated tree in 3ds max. I exported it fine with Cal3d except for the fact that the branch texture only appears on one side of the planes. If I export it as osgb it looks fine but lacks animation.
I see that there is a cullFace method that can swap which side of the plane has the texture but i can't disable it completely. (why??) likewise the inspector can turn it off but i have no way of saving it.
Any help would be much appreciated!!!
thanks!!
Old 11-18-2015, 03:39 PM
Currently changes made in Inspector can only be saved to OpenSceneGraph formats, but not avatars. To disable backface culling for the leafs, you would need to check the '2-sided' option in 'Shader Basic Parameters' in the object's material. You could also do this through the Vizard code:
model.disable(viz.CULL_FACE)
Old 11-18-2015, 04:03 PM
Thanks so much Jeff.
The textures appear on both sides now, but looking from below the transparency still has a substantial outline. Any way to remedy this?
3dsmax, animation, cal3d, cullface, texture
How to make neck of avatar invisible Frank Verberne Vizard 4 02-05-2014 06:39 AM
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 03:58 AM
How to make avatar always in front of youself (e.g. 20cm) when direction changes Xianshi Xie Vizard 2 06-30-2009 12:13 PM
Max -> Vizard, Two Sided Textures shivanangel Vizard 5 12-04-2008 04:15 AM
