Old 07-23-2015, 04:22 PM
Daniel Daniel is offline
Drawing trajectory of an object
It is possible to attach the pencil tool to an object and draw its trajectory?
Or there is a better way to do that??
I'm doing a robot kinematic simulator and I want to display the end effector trajectory
Old 07-24-2015, 12:44 PM
Yes, you can link the pencil tool to any object. You could either activate the pencil draw command with an input signal (mouse button, keypress, etc.) or have it draw continuously.
Old 07-24-2015, 03:14 PM
Hi Jeff, thank you for your answer
Could you please show me an example of a pencil attached to an object and drawing continuosly? Because I can't make it work properly
Old 07-28-2015, 06:06 PM
Take a look at the pencil documentation for commands available. The following example script executes the draw command continuously:
Right mouse button clears the drawing.
Middle mouse button changes color.
Mouse movements control viewpoint orientation.
Arrow Keys control viewpoint position.
import vizshape
import vizinfo
vizinfo.InfoPanel(align=viz.ALIGN_LEFT_BOTTOM)
viz.setMultiSample(4)
viz.fov(60)
piazza = viz.add('piazza.osgb')
arrow = vizshape.addArrow(length=0.2, color = viz.RED)
from tools import pencil
tool = pencil.Pencil()
# update code for pencil
def update(tool):
	state = viz.mouse.getState()
	if state & viz.MOUSEBUTTON_RIGHT:
		tool.clear()
	elif state & viz.MOUSEBUTTON_MIDDLE:
		tool.cycleColor()
		tool.draw()
tool.setUpdateFunction(update)
#Link the pencil tool to an arrow
#Then move the arrow in the reference frame of the viewpoint
from vizconnect.util import virtual_trackers
mouseTracker = virtual_trackers.ScrollWheel(followMouse = True)
mouseTracker.distance = 1
arrowLink = viz.link(mouseTracker,arrow)
arrowLink.postMultLinkable(viz.MainView)
viz.link(arrowLink,tool)
import vizcam
vizcam.FlyNavigate()
#Hide the mouse cursor
viz.mouse.setVisible(viz.OFF)
Old 07-29-2015, 10:41 AM
Thank you Jeff, but what I can't do is to attach the pencil to an osgb object (in this case the robot end effector), how can I do that?
Thank you in advance
Old 09-24-2015, 03:31 PM
Could you please help me to attach the pencil tool to an osgb object?
Old 09-25-2015, 01:45 AM
Samuli Samuli is offline
Have you tried to modify the pencil example code like this:
robot=viz.add('your_robot_name.osgb')
arrowLink = viz.link(mouseTracker,robot)
Old 09-25-2015, 11:43 AM
I've tried it , but if you add mousetracker , I end up drawing with the mouse.
What I want is to attach the pencil to the end of the robot and the pencil draw the trajectory of the robot end effector
Old 10-08-2015, 04:53 PM
You can parent or link the pencil tool to any node in Vizard.
Rotate object around mainView? performlabrit Vizard 3 12-19-2013 07:31 AM
AMD graphics hardware seems not to preload object sleiN13 Vizard 2 03-20-2012 07:08 AM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
