Old 09-08-2005, 02:16 PM
bailenson bailenson is offline
2.53 render window problem
Hello.
I just installed 2.53 and am having a problem in which the render window is all white and won't show any objects, etc.
This is occuring on multiple machines.
Any suggestions?
Jeremy
Old 09-08-2005, 02:29 PM
I just checked the video cards of these machines and the problem may be that the cards are only gforce 2 cards--this worked fine with the previous version we had on there, but not the current version (which indicates a need for gforce 3)....
Old 09-08-2005, 05:03 PM
So version 2.51 worked fine on the same machine with a Gforce 2, but version 2.53f does not? Upgrading to a newer card might help, but either way we will try to fix the problem. Does this happen with all scripts? Can you try running a basic script that just calls viz.go() and see if the problem still occurs?
Old 09-08-2005, 05:05 PM
it was a driver problem
Hey, it was a driver problem, not a Viz problem at all. Sorry to waste your time,
jb
